Home > Technical > 300tdi re map
Culminator
300tdi re map
Of the many "re map" threads on the forum, I'm not sure if I've ever seen anything regarding the 300tdi engine. Is this because this derivative pre dates mapable ECU's or is there indeed a useful mod to be had?
Post #247985 1st Jul 2013 10:37am
camelman
Unfortunately, there isn't an ECU to remap Very Happy
You can go with a bigger intercooler and uprated pump to get up to around 140bhp
Post #247986 1st Jul 2013 10:46am
RobKeay
First make sure your engine is in tip top condition. Oil, all the filters and check timing is right.
Then remove egr valve if it has one. Put a de cat pipe on if needed.
Buy a better intercooler then your new intercooler will come with instructions on how to tweak the fuelling.
It does make a fair bit of difference but if your engine isn't right in the first place spend your money on making it run well. Sometimes it's a poorly running engine that makes you think you need to boost the power. The 300tdi needs servicing every 6000 miles.
Post #247990 1st Jul 2013 10:56am
Culminator
OK, thought as much but good to get confirmation.
I'm actually very happy with the engine at the moment, already has EGR blanking plate and decat pipe. It's been regularly serviced but I'll check the air filtre just in case.
It had a splash of 2SO in the tank at the weekend, so it'll be interesting to see if there's any difference in smoothness tonight when I use her.
Thanks
Post #248010 1st Jul 2013 12:32pm
RobKeay
Sorry teaching you to suck lemons there.
Mate of mine is always messing with his 300 but seems not to bother with the maintenance sheet. Just fix when broke.
He has a better intercooler but has to back the fuel right off to get through mot.
Post #248013 1st Jul 2013 12:56pm
Culminator
Not at all, always lots of new info on here and I have a lot to learn about my new toy!
Thanks for the info...
Post #248019 1st Jul 2013 1:18pm
jst
https://www.defender2.net/gallery/albums/u..._Rev_2.pdf
should all be explained above. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #248038 1st Jul 2013 2:25pm
Culminator
Thanks James, an excellent read. I'll have to go through that a few times to fully understand it but well worth the effort I'm sure!
Post #248043 1st Jul 2013 2:43pm
jst
feel free to post up once you have digested it. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #248155 1st Jul 2013 8:18pm
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
fit one of our big turbo's........... Whistle Putting Dreams on Drives at JLR Solihull..
Post #248938 4th Jul 2013 8:37am
