![]() | Home > Technical > Indicator auto cancel |
Sockpuppet Member Since: 17 Sep 2011 Location: Leicester Posts: 479 ![]() ![]() |
Its usually a ring on the steering column to reset when the wheel points forward. I'd start looking at that or the stalk.
Pop the wheel off and there are usually two pins that auto cancel. Self-explanatory once the wheel is off.
![]() Treat every day as if it is your last....one day you will be right!! |
sweatysock Member Since: 17 Jul 2011 Location: Warwickshire Posts: 283 ![]() ![]() ![]() |
Thanks, will have a look around those areas today Sweatysock
------------- 110 CSW TDCI (Puma) 2007 |
