Home > Puma (Tdci) > Driving Lights Wiring |
Bum steer I'm afraid fellas! Less haste next time: Sorry! The driving light switch with the number 2 in it is part no YUG 000540LNF purchased from www.britishparts.co.uk or your local dealers. The relay bases and switch connector and contacts were purchased from dingocroft. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
17th Feb 2010 8:17am |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
Switch sorted thanks to The Boy... K9 me old Mucker that's the other part i was after anyway mate the relay bases and switch connector....Nice one so no bum steer on my behalf NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
17th Feb 2010 10:15am |
MuddyMarky Member Since: 01 Feb 2010 Location: Oxfordshire Posts: 548 |
Pic whoring opportunity with the new lights & roof rack!
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mark 2011 110 XS DC Stornoway Grey |
17th Feb 2010 5:16pm |
Looking Cool MM NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
17th Feb 2010 7:04pm |
ay4alex Member Since: 18 Feb 2009 Location: Midlands Posts: 328 |
Looking great MM, but you might want to check the legality of that bull bar, I've been told multiple times that you can't fit them to new cars. 110 Tdci Double Cab
17th Feb 2010 9:25pm |
MM I,ve had one on for over 2 years with out any problem...i suppose its the look of the draw NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
17th Feb 2010 9:41pm |
Yes, I know about the a-bar. Heard varying things about them.. some say about not legal to manufacture/sell them, but ok to fit, others say not legal to fit unless you have good reason ie: agricultural use etc. I live in an area with loads of farms, etc so could probably blag it. Also the police are extremely tolerant round here of things such as the tints, no plate spacing (and size of plates on motorcycles), so I'm going to just see what happens- love the look of it, anyway - also, seems to worry little cars in traffic Mark
18th Feb 2010 9:02am |
nicks Member Since: 21 Aug 2008 Location: south coast Posts: 469 |
i have the same on mine, only i've remaned it to "light mounting bar" got away with for a couple of years |
19th Feb 2010 11:45am |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
You're fine to fit the a-bar. Only illegal to manufacture and sell for road use. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition |
23rd Feb 2010 7:57am |
Thought that was the case too, Alan..... thanks for confirming it for me though Mark
23rd Feb 2010 2:20pm |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2117 |
Hi All,
I've got the lights fitted and wired in - all works well, got the same switch as in the fab photos but cant get the LED light to work on the switch .. anyone know how to wire this in ..? any help would be great Wyvern Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
6th Mar 2010 12:50pm |
If you've used the switch part number YUG 000540LNF it contains two LEDs one green one and one red one. The switch has 5 pins and should be wired as follows if memory serves me right:-
1. Earth switched - connect to relay coil 2. Dash illumination (green LED) - connect to dashboard illumination 3. Earth 4. Redundant. 5. Plus control light (red LED) - connect to load feed after relay. Hope this helps. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
6th Mar 2010 4:27pm |
Cheers K9!
I'll give it a try and let you know how I got on... Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
6th Mar 2010 5:52pm |
