![]() | Home > Puma (Tdci) > How to disable my 2010 2.4? Which fuse to pull out? |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6324 ![]() ![]() ![]() |
might be safer to stay at home and play call of duty
![]() only joking. I'm not sure they is. I understand the ecu has more than one supply. either way I'll be interested to find out too. good luck. |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 810 ![]() ![]() |
You would have to remove or loosen the heat shield...
But if you unplug the crank sensor the Land Rover will not start... and will confuse most thieves. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
Norm4n Member Since: 31 Aug 2012 Location: Surrey Posts: 329 ![]() ![]() |
Ian
Is that easiest to locate from lying underneath, or from under the bonnet? |
I'm pretty sure from above but hopefully Ian (or someone) can confirm for sure.
Rakthi Member Since: 30 Nov 2012 Location: Where the cats are Posts: 200 ![]() ![]() |
The crank shaft sensor is situated under its own little heat shield. You will have to wait for the engine to cool down enough to unplug it. I think will be easier from above. (that little shield on my car rattles like mad)
If you go for fuses .. if the perp is smart, he will check the fuses and see there are some missing, he can then just jump them or use a fuse from another position. Should you go that way, best would be to get some blown fuses / relays and put those in place of the good ones. You could download the manual and check out which fuses / relays would be best to replace with defunkt ones. |
roamingman Member Since: 15 Mar 2012 Location: nearly thier Posts: 152 ![]() ![]() |
Hi I can understand the reason for your post,
but you have just told maybe some dubieous people how it could be done, better to have had the replys in a PM or email. I also have been thinking about diableling my old Defender, good luck with your trip and hope it all geos well. Live Life Ti'l You Die Teddys are out thier http://teddybearspicnic.webs.com http://130sasha.co.uk/ |
HMARR Member Since: 04 Jun 2013 Location: New Zealand Posts: 56 ![]() |
Thanks for the tips guys - You make a good point Roamingman... although I think the risk is very low. Doesn't seem to have a lot apparent New Zaland traffic on this site, although I could be wrong. this might be my last post as this time next week I will have died of exposure. gulp.
NoDo$h Member Since: 18 Aug 2007 Location: Buried in deer guts in Dorset Posts: 972 ![]() ![]() |
No, because you'll be leaving the Long/Lat of your parking spot with at least two friends/relatives with instructions to notify the emergency services if you haven't called them both by xx:xx hrs on dd/mm date. I expect you'll also hide a stash of extra food, clothing and a more substantial shelter near there too
![]() ![]() 54 Freelander modded for mud 2008 D3 SE 2010 90 XS SW 1978 88 Series 3 undergoing surgery with a new owner 2007 90 County Truck Cab - gone 2006 D3 SE - gone 2004 Freelander Sport - gay 1999 Disco V8 ES rotted to bits |
What Al said
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
Make sure what ever you do you put it in a location where you can push start the car, if someone does get in it they may flatern the battery just trying to start it.
Shame you have not got the BAS remap interface as I could have made a special NO TORQUE caliobration which allowed the car to start and idle but had a maximium speed limit of 5kmh and gave not torque upon accelleration. Though they may have got the car started they would not get far and at least would not flatern the battery trying. Pete |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17679 ![]() ![]() ![]() |
Pete,
That is very interesting, I had in mind asking you if it was possible to do that! How much would you charge for an anti-theft, zero torque security map? Roger |
If you are having my BAS interface id do it as a favor on inital set up as i will have your tuning projectal ready open as a work in progress setting up the interface with thetuning files.
Pete |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6161 ![]() ![]() ![]() |
Why not just unbolt the ECU and stick it in your rucksack? that'll disable it!
If you could get a knackered ECU you could remove the whole guts out of it, and re-fit that in so the perps wouldn't think it was that causing the problem. However, if you're in the middle of nowhere, and someone comes up to steal your truck, what's the likely that they'll just tow it away anyways if it won't start? |
BAS - you are definitely on the shopping list. That would be a great feature to have along with the usual tuning files... and point noted about the battery. Quite a bit to consider when trying to disable! In the past I've always left an open gun case in the back and a few empty .308 shells lying on the seats inside in full view. That usually sends a clear message of who could be coming over the hill to catch them in the act.
