Home > Puma (Tdci) > Wipers not working
Ric
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Wipers not working
Hi, in the past I've had problems with the wipers not stopping as they should and also they're erratic on the intermittent setting.
But now they've just decided not to work!
Any ideas,
Ric its only a car!
Post #242791 11th Jun 2013 4:05pm
mk1collector
Wiper park switch or one/both of the wheel boxes are seized. Both are reasonably cheap and I'd start with the park switch. Also only get genuine Landrover park switches as I've found cheaper makes last about a month Thumbs Up
Post #242799 11th Jun 2013 4:29pm
Most likely the park switch on the motor, it seems to be the least reliable component! Failure can cause the wipers the stop randomly, or to stop altogether, or even to run continuously.
It's a bit of a pita to get at on the Puma without totally dismantling the dash but it can be done. I did post a "how to" some time ago, if you use the search facility you should find it.
Post #242802 11th Jun 2013 4:36pm
IanW
United Kingdom 2008 Defender 110 Puma 2.4 CSW Zambezi Silver
Wiper parking
Similar problem with my Puma a couple of months ago. There are a couple of relays in the fuse box under the steering column. Problem resolved by gently wiggling the wiper relay about (red one from memory). Might be worth a try. Ian One wife - livid
Post #242810 11th Jun 2013 5:10pm
Ric
Thanks all, where is the best place to get the park switches from, does anyone have the landrover code, maybe try duckworths
Are they an easy fit, any images or pics would be a great help
Thanks
Ric its only a car!
Post #243465 14th Jun 2013 7:37am
Ric
Right, changed the wiper motor park switch, total pita.
Also just before changing the above i found the fuse for the wipers had blown, so replaced that.
both of these have resolved the problem?
any suggestions apart from rain x! its only a car!
Post #245780 23rd Jun 2013 12:00am
WarPig
I've just had the exact same problem on my 300tdi and it ended up being a faulty wiper motor. The fuse was constantly blowing and intermittent setting was erratic.
Post #245808 23rd Jun 2013 8:33am
Ric
Tried another relay in it today and no improvement so it looks like a new wiper motor,
Landrover part or a motor spares copy? its only a car!
Post #246091 23rd Jun 2013 8:17pm
sweatysock
United Kingdom 2007 Defender 110 Puma 2.4 CSW Indus Silver
My beastie had a similar prob recently, turned out the wiper cable had actually snapped so stripped down dash needed....according to the man in the greasy suit....the car is still under warranty so I did not look myself Sweatysock
110 CSW TDCI (Puma) 2007
Post #246126 23rd Jun 2013 9:30pm
mk1collector
Go genuine. They are surprisingly affordable in comparison to after market
Post #246139 23rd Jun 2013 10:41pm
WarPig
When my Defender was 15 yrs old I had a new bulkhead fitted and decided to put a new wiper motor on at the same time, even thought there wasnt anything wrong with the original one. Because I needed one quickly I bought a Britpart motor.
Fast forward 2 yrs and the Britpart motor has just failed. Compare this to the original motor which was still working OK after 15 yrs.
Lesson learnt Neutral
Post #246140 23rd Jun 2013 11:07pm
dorstsmith2
United Kingdom 2003 Defender 90 Td5 HT Caledonian Blue
Britpart and moving parts not good Rolling with laughter
Post #246178 24th Jun 2013 8:21am
I don't remember EVER buying a Britpart part which wasn't defective or unsatisfactory in some way, and I try to avoid them like the plague (and will only ever buy them when I need something in a hurry and nothing else is available).
Highlights over the years have included:-
- A Disco2 air filter which physically didn't fit in the air filter housing
- Defender hub nuts (the stub axle nuts) which had the wrong number of TPI and destroyed the stub axle (making the repair much more expensive)
- A Defender door mirror which didn't fit the mirror arm ball.
There have been others, but I have managed to expunge them from my memory!
However the most recent Britpart part I bought was a bump rubber for a Disco 2 (needed urgently because of an MOT). The original part's metal backing plate was perfectly formed and about 1.5mm thick; the replacement's was bent out of recognition and so thin you could bend it between finger and thumb like cardboard.
Very depressing really.
Perhaps we should start a parts "Hall of Shame" thread.
Post #246201 24th Jun 2013 9:44am
gbmud
2005 Defender 110 Td5 HT Belize Green
Do you mean that neither of these has resolved the problem?
Has the fuse blown again? If so, try this: Remove the wiper arms and then the motor and 4' long operating rack/cable. Rotate both shafts that the wipers fit on 180 degrees (they should turn easily now) and then refit everything. The wheels in the wiper boxes wear and get stuck on the operating rack/cable. By rotating 180deg you are now using a new part of the wheel and all should be well.
Failing that, check that there is power arriving at the motor when you operate the switch!
Chris
Post #246206 24th Jun 2013 10:02am
dorstsmith2
we should pill all failed Britpart parts outside the factory gages this stop then sending out parts Whistle
Post #246212 24th Jun 2013 10:16am
