Home > Technical > Hawkeye or Lynx?
taffrican
Wales 2002 Defender 90 Td5 HT Java Black
Hawkeye or Lynx?
As title says, which is the better diagnostics tool? and why?
Thanks
Mike Optimists say the glass is half full..
Pessimists say the glass is half empty..
Engineers say the glass is twice the size it needs to be!
Post #245249 21st Jun 2013 1:21am
dgardel
Italy
Re: Hawkeye or Lynx?
Thanks
Mike
Nanocom EVO? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #245267 21st Jun 2013 7:04am
taffrican
That could be added to the list, but then again it is over £100 more, can anyone justify a 3rd more in price? Optimists say the glass is half full..
Post #245273 21st Jun 2013 7:59am
K9F
Maybe because it's recommended by this guy too perhaps?
bell-auto-services wrote:
If you want mobile standalone use on any TD5 engine diagnostic tool then you need a Nanocom Evo. {ete
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #245275 21st Jun 2013 8:02am
taffrican
does that justify £100 extra? Optimists say the glass is half full..
Post #245277 21st Jun 2013 8:06am
K9F
I wouldn't know myself but if I was in the market for a diagnostic tool on the basis of what both Pete and Daniele recommend that would be good enough for me personally.
Drop them a 'PM' you'll get a quicker answer. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #245279 21st Jun 2013 8:11am
taffrican
I just read the topic above this one, lot's of reading to be done to read all the links as well, nightshift again tonight, I'll read it all then Thumbs Up Optimists say the glass is half full..
Post #245283 21st Jun 2013 8:18am
Does this mean:-
a) that a Nanocom Evo is not VIN-locked, and/or
b) that a Nanocom Evo for Td5 will work on both Disco2 and Discovery?
Post #245298 21st Jun 2013 9:04am
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
They are not VIN locked but certainly model specific so you couldn't use a TD5 on a Disco
Post #245337 21st Jun 2013 11:11am
But a Disco2 Td5 Nanocom Evo should work on all Td5 Disco2's, and a Puma Defender one should work on all Puma Defenders?
Interesting info, many thanks! Thumbs Up
Post #245350 21st Jun 2013 11:57am
kmac
Correct
Post #245378 21st Jun 2013 1:39pm
kmac
For the Puma I'm not so sure the Nanocom is worth it - if its brand specific error codes you want a cheaper code reader such as Sealey VS8702 http://www.toolstop.co.uk/sealey-vs8702-eobd-code-reader-p57417
Now the Nanocom has no manual as such so maybe it has loads of other features that i don't know about.....
Post #245384 21st Jun 2013 1:54pm
