![]() | Home > Td5 > COOLANT leak with no hole.. |
ttuck3r Member Since: 03 Feb 2013 Location: Dunning Scotland Posts: 277 ![]() ![]() ![]() |
So today i was running late for work and the defender got thumped the whole way to work, at the end of the day i noticed a small puddle of coolant under the engine. popped the bonnet and there was coolant sitting on the right of the engine and about 300ml missing out the bottle.
Here's the conundrum, there is no trace of where its come from, i've put a pressure tester on the expansion bottle and taken it up to 13 bar with no leaks and ive topped her up and driven home with no recurrence. This is where the coolant was sitting. ![]() Click image to enlarge ![]() |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5800 ![]() ![]() |
The small hose clip in that photo looks suspect, also check the screw in core plug that goes into the side of the cylinder head in between exhaust manifold webs.
Shown here http://www.bing.com/images/search?q=td5+en...edIndex=16 Andy |
Thanks i will have a wee look at the core plug in the morning..
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 ![]() ![]() ![]() |
Is that an EGR pipe I see in that photo
![]() JD 2008 TDCi 2.4 XS CSW |
It is indeed, i'm in the process of looking up which EGR blanking kit is best aluminium vs steel and pricing. |
WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
When I had a similar problem with my 300tdi it was coming from the water pump gasket. The water pump can be found behind one of the belt pulleys.
If you pop your bonnet with the engine running, pull on the accelerator cable and look for fine splashes/spray of coolant. If you cant see it spraying out, look for splashes on other engine components around the water pump. Or close the bonnet, rev engine with pedal, lift bonnet and look under the actual bonnet where it may have splashed up onto the underside. Worth a try. |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6124 ![]() ![]() ![]() |
My 90 dribbles from exactly the same place.... i've tried re-seating the pipe (it was damp on the bottom of it, so has to be where the clip is)
Might change the clip for a proper jubilee clip that can be done up tighter. |
