Home > Maintenance & Modifications > Steering Guard
DRW58
Scotland 2001 Defender 90 Td5 SW Epsom Green
Steering Guard
I'm contemplating the purchase of a steering guard for my TD5, I've looked on several websites and there seems to be a significant variation in price from about 40 quid up to 180 plus, between the steel and aluminium ones.
I'd like to know what the benefits of going for an aluminium one as opposed to steel, and where I might get the best deal?
I've seen some comments about the aluminium ones cracking?
Having just replaced some of the steering gear I'd prefer to protect the new stuff.
Dave I built a garage for my Mini
With a place for everything and everthing in its place.
Ten years down the line there's a Mini in there somewhere, and Censored all's where it should be!!!! Ho hum
Post #244819 19th Jun 2013 9:06am
x-isle
Alloy looks a bit nicer when bare. Steel will/should be galvanised so not too shiny.
The brackets shouldn't be alloy, they should still be galvanised.
As for thickness, if going for an alloy plate with galvanised brackets, you should go for 10mm brackets and 8mm plate.
If you go for all galvanised, then you don't require the plate to be so thick.
After looking around for mine, I ended up going with the Paddocks PM716 as the price is great and the finish is actually brilliant. http://www.paddockspares.com/pm716-heavy-d...ender.html
The other thing to consider is are you going to actually use it or is it for show? If you are going to be smacking the life out of it every couple of days, then possibly the full galvanised one would be better.
In my opinion, if there is a chance that you will be using it, even occasionally, then I wouldn't go for any painted or powder coated one. Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #244826 19th Jun 2013 9:59am
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
Possibly a bit late now as you say you have some new steering components but instead of a guard i went for solid steering bars. Less additional weight and keeps the front looking standard. Also for the purposes of farming and lanes amply strong. Rhubarb and custard let fly with their secret weapon.
Post #244831 19th Jun 2013 10:22am
leeds
A few things to consider.
Some of the steel steering guards are electro plated and not hot dipped galv. OK a smoother finish but nowhere near as good for rust resistant.
Get some with built in recovery eyes unless you have them already built in on a bumper.
Avoid el cheapo ones on the bay as I have seen them fracture around the bolt holes.
Yes you can get one powder coated a nice bright pink colour or boring black if you so wish.
Brendan
Post #244834 19th Jun 2013 10:44am
Don't see the point in Alloy myself being weaker. Only plus point is weight but is that really an issue on a Defender?....
Rebel 4x4 galved steel one on mine. Previous owner fitted (glad he did) and has been on for over four years with not a single problem at all. About 10mm think I think.
*Edit built in recovery eye's too* ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #244837 19th Jun 2013 11:25am
Probably 5mm Steve, 10mm steel would be really heavy Thumbs Up
Post #244839 19th Jun 2013 11:53am
DRW58
Thanks for all the suggestions, I opted for a galvanised job from Paddocks with towing eyes, I don't expect to be doing anything too extreme, but better to be safe than sorry.
Plus it will look cool with the new chassis Thumbs Up
Need to go SWMBO needs her tea and apparently I'm chef for tonight.
Need to keep her sweet it our anniversary tomorrow. Whistle Embarassed
Post #244898 19th Jun 2013 5:28pm
DRW - Rolling with laughter Rolling with laughter I would if I was you to be on the safe side. Razz
Go Beyond - Your probably right. Can't be bothered to go measure it to prove my guard dimensions. Laughing ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #244900 19th Jun 2013 5:31pm
The Land Rover standard one is worth considering, I've had mine on for 3 years now and it still looks good.
Post #244902 19th Jun 2013 5:52pm
K9F
Agree with BPman I've got the same as above and it was the same one fitted as standard to the SVX. The one I have 'has done the rounds' and been fitted on two previous forum member vehicles. I had it stripped, dipped and powder-coated and I too think it is a decent looking guard.
Thumbs Up
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #244904 19th Jun 2013 6:03pm
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
I am thinking of removing mine and fitting the military style bar and possibly dan bars. Mainly as I am putting a multi mount on the front for the snowplough and winch and don't want to cut the guard but partly I find when I am stuck it acts a a plough when being recovered backwards and lifts the front wheels out of traction when going forward
Post #244905 19th Jun 2013 6:15pm
mrandmrsh
United Kingdom 2015 Defender 110 Puma 2.2 USW Santorini Black
Mal, what are those front recovery points? Nice looking front end.
C 2015 110 USW XS in Santorini with premium contrast leather seats in tan/black, black headlining and with Dual Finish alloys (in the garage, now on Wolf rims with Goodyear MT/Rs)
2012 '62' 2.2 X-Tech 110 USW now gone ...
1984 90 soft top with full roll cage, 200 tdi engine etc now sold
2012 USW XS 2.2 "FUU" now gone....
Post #244908 19th Jun 2013 6:29pm
K9F
Thanks. Front end currently in pieces for ongoing current modification at the moment. 316 stainless bowshackles attached to the recovery eyes on my HD bumper. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #244910 19th Jun 2013 6:42pm
familymad
Thumbs Up
Is that a Terrafirma bumper? 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #244913 19th Jun 2013 6:47pm
K9F
Not Terrafirma.....First Four.
http://www.firstfour.co.uk/item/714342/def...ent-bumper If you go through life with your head in the sand....all people will see is an ar5e!!
Post #244921 19th Jun 2013 7:25pm
