![]() | Home > Td5 > Has my 1998 td5 got an inter cooler |
SteveT247 Member Since: 21 Feb 2011 Location: Central Posts: 491 ![]() ![]() ![]() |
Yes it has, but a stage 2 will require a bigger intercooler than the standard factory one I believe.
Postmanpat Member Since: 01 Aug 2012 Location: Co.Limerick Posts: 50 ![]() ![]() ![]() |
it does , and you can't overwritte your ECU either ... Postmanpat
amondeggs Member Since: 06 Mar 2011 Location: Telford Posts: 452 ![]() ![]() ![]() |
This is correct if the label on the ECU say it is a MSB type you can swap it out for a NNN type that can be reflashed This I what I have on mine ![]() |
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 ![]() ![]() ![]() |
It had already been swapped out prior to me getting the Landy.....I have an NNN one
thats already a help ...
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
all you need now for a stage 2 is a remap larger cooler and a boost box which allows yu to ajust the turbo
![]() steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
