Home > Maintenance & Modifications > Anyone pulled a GKN overdrive to bits?
appaloosadude
United Kingdom 2003 Defender 110 Td5 DCPU Havana
As per title really.
I think I'm going to have to strip mine out to change the cone clutch and/or the one way bearing, and was wondering if anyone had done anything similar.
Martin at D44 tells me its do-able for a competent spanner-er, so I think I should be ok... However, its much better to learn from other peoples mistakes than your own ( and cheaper!!)
Thanks in advance.
Post #239535 29th May 2013 7:56pm
natyeo
United Kingdom 2014 Defender 90 Puma 2.2 HT Santorini Black
GKN Overdrive
Hi did you strip it down yet? did mine a year ago, if you go onto google and look up gkn & laycock overdrives you'll find a layout drigram , gkn took over the old laycock design which was fitted to BL cars and instead of drive going in / out either end to in / out same end , it was ok to strip and re build but easier with an extra pair of hands , if you need the diagram I will add it here 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb
2012 2.2 tdci 110 Utility
1993 110 CSW Warn M8000 , Scorpain winch bumper , 2" lift , Roamerdive overdrive, on going
1971 Hybird 200tdi, 2 x truetracs,Extrem winch bumper, M8000, GKN overdrive & Coils 2" lift, Glynn Lewis cranked rear trail arms
1971 Series 3 88, Perkins 4203,M8000,SATs,O/D,
Post #243317 13th Jun 2013 8:23pm
appaloosadude
That would be great, I can't seem to find Buckeye Triumphs web pages anymore Sad
Post #243378 13th Jun 2013 10:25pm
natyeo
Very sorry I cannot add a bloody drawing of this whats your e mail I will send to you 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb
Post #243456 14th Jun 2013 8:08am
