![]() | Home > Td5 > Exhaust manifold options |
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1385 ![]() ![]() ![]() |
we have some skimmed ones on the shelf, fit that with our stud kit......... Putting Dreams on Drives at JLR Solihull..
adseybear Member Since: 08 Oct 2009 Location: Vancouver, Canada Posts: 262 ![]() ![]() |
Can you give me an idea on prices?
And am i going to have trouble extracting snapped studs? 2003 Defender 90 Td5 CSW Belize Green - "Betty" 1958 Series IIA 109 Station Wagon - "Randolph" - Awaiting Restoration 2019 Jeep Wrangler JL Rubicon - SOLD 2006 Volvo V70 D5 - Ocean Race Edition, SOLD 2003 VW Passat Estate 1.9TDI - SOLD 2008 BMW 320D M Sport Estate - SOLD 2001 Defender 90 Td5 Hard Top - SOLD |
yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 713 ![]() ![]() ![]() |
I skimmed mine & changed the studs for Wurth ones. The studs were about £16. One was broken but not too bad to extract.
not unless you take care...drop me email.... ada@irbdevelopments.com sort something out for you... Putting Dreams on Drives at JLR Solihull..
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
As Ada says you want one which is skimmed the ribs removed and bigger bolts job done
![]() Steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6145 ![]() ![]() ![]() |
Allisport do a nice new cast one, without the EGR hole on the end. don't know about price though.
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1434 ![]() ![]() ![]() |
JE engineering (Coventry)will supply the stud kit- and will swap the manifold for a skimmed one about £400fitted IIRC. Or just get the stud kit, change yourself (probably have to dill and tap a stud or 2) and get a local engineer to skim your existing manifold about £50
It is nice Jim but when I enquired it was £800!!! |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 810 ![]() ![]() |
I disagree..... from some test work I did on a customers vehicle, removing the webbing made no difference, and 10mm studs might solve the problem for a bit, but not needed. Also, making the very back stud 10mm means you get very close to the water jacket... which if you break into scraps the head. A skimmed manifold with a few tweaks and a stud kit with spacers to help heat dissipation - the manifold will be problem free.... unless your running stupid mapping. Also, if needed I have a proper jig I will rent out to allow you to centre holes properly. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
oi you ^^^^^^ did you get my email about Friday ?.......bring me something back nice too....
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 ![]() ![]() |
I have one of Ian's skimmed manifolds with an uprated stud kit and it's been perfect now for 3 years despite the heavy work I make it do. www.td5.org
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 ![]() ![]() ![]() |
Am I likely to get this screaching issue with a stage one remap .
JD 2008 TDCi 2.4 XS CSW |
Not sure about likely, but certainly possible. It depends on how it's driven and used. My 110 was remapped about 5-6k miles ago and is fine so far but my wifes old DII only failed in this way after about 30k miles so it's difficult to say. Darren
Hmm thats a bit worrying, do'nt want to have to spend another 500 Quid + after 300 for a remap......any other possible side effects of a stage 1 ?
