Home > In Car Electronics > My Kenwood ICE Upgrade
Page 2 of 2 <12
Yes and no. Whistle Yes they will if you use existing holes but will be at an angle. If you want them straight like mine you have to drill as I did but all the fixings are supplied. Check and check and check again before drilling the hole are correct and you will be fine. Don't be put off by it. I took a CD pen and the grille and lined it up and marked the dash first then drilled. As I said don't drill until you know it's perfect.
Electrical wire one plug can be plugged straight in no problem the other is too small. There is no way around it other than to remove the one that is too small and I crimped on a female spade terminal. (A blue one if you want to be specific but red would be fine too) Also needs to the be fully insulated type.
 TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #242231 9th Jun 2013 1:43pm
Innuendomaster
Brilliant thank you. Pictures are better than words, you've been a valuable help to me and appreciate it.
Post #242232 9th Jun 2013 1:47pm
No probs. Thumbs Up The metal clips you see are supplied in the box with the speakers along with screws. Although personally I used the original torx screws as they are more secure. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #242234 9th Jun 2013 1:49pm
Page 2 of 2 <12
