Home > Maintenance & Modifications > checker plate match
theorangebandit
checker plate match
Wondered if anyone can help me locate a match for my checker plate. Id like to plate the bonnet and the rear cross member. I have the land rover fitted plate kit(come with the car). The plates aren't sprayed although they don't seem naked if that makes sense. They look treated
Any help would be great as I keep standing on my bonnet when using the roof bars
Post #242149 9th Jun 2013 7:11am
leeds
Chequer plate on rear cross member? NO
Normally put on rear cross member to either try and disguise a 'tired' ie rust box of rear cross member. OR it will help make rear cross member a rust box!
Brendan
Post #242153 9th Jun 2013 7:22am
GUM97
It sounds like you have Anodised chequer plate. But as Brendan says, don't out it on the rear cross member. It can trap water and dirt behind it, and speed up corrosion. An engine to TDi for!
Post #242154 9th Jun 2013 7:25am
theorangebandit
Thanks for the cross member advice lads ill avoid the idea now. Also anodised plates is what ill try to locate for bonnet. Any idea of a good location to get the thin matting that fits between plate and paint work ?
Post #242155 9th Jun 2013 7:33am
The thin matting is neoprene and is usually about 2mm thick. If you buy from somebody like Mammoth then I think they do these gaskets for all of their products.
Site sponsor Defenderbits supplies Mammoth chequer plate. Darren
Post #242159 9th Jun 2013 7:39am
theorangebandit
Mammoth bits, im on it thanks
Post #242160 9th Jun 2013 7:44am
