Home > Technical > Noise killer
Page 2 of 2 <12
Cakey
United Kingdom 2012 Defender 90 Puma 2.2 XS CSW Santorini Black
Quick update , fitted the Velcro heavy duty (thanks k9f) it appears to stick ok ish .
Not fell off yet but not quite perfect. May need to add some acrylic red gel tape to fix it proper.
Post #241496 6th Jun 2013 6:03pm
ZeDefender
My last resort is always PU adhesive foam ("Arbofoam" in UK?). It is sold as "foam glue" here. I've yet to find something it won't stick... permanently. Downside is that it is pretty much impossible to clean off. Tell someone you love them today because life is short.
Post #241541 6th Jun 2013 8:00pm
Cakey
Time for last resort Sad
Post #241846 7th Jun 2013 9:29pm
ZeDefender
You can get Soudal (original brand) at B&Q Thumbs Up
http://www.diy.com/nav/build/building-mate...kies=false
Try to get one sold as "Adhesive" - it probably won't foam as much. Test an area first for adhesion and see how you get on with the expansion characteristic - bear in mind it will initially "push" outward as it foams (you have to keep "knocking it back")... and do not get it anywhere you do not want it! It's triggered by moisture in the air - so no problem in the UK or here Laughing
Couple of other tips:
1) It often comes with 2 or 3 spare nozzles (tubes) - if you want to do multiple applications try to get some, as it sets inside.
2) When you stop applying it, it will keep expanding in the tube... and drip wherever you put the can. I make this mistake every time Rolling Eyes
3) The leftover foam will set in the can after a few weeks. Tell someone you love them today because life is short.
Post #241877 8th Jun 2013 6:25am
Cakey
Just fitted it with the adhesive as per zezee Bow down Bow down Bow down Bow down
Touch wood its stuck like s&&t to a blanket . I will report back if it stays put. Looking very good though .
Couple of tips
Watch the nozzle for overflow
I ran 3 lines of foam on each piece , as it collapses when you push it back . 15 mins to tacky 45mins solid .
Post #242014 8th Jun 2013 5:05pm
mk1collector
You must make sure all old adhesive is off the area before you use new adhesive or it eventually will come apart again Thumbs Up
Post #242033 8th Jun 2013 6:38pm
Page 2 of 2 <12
