![]() | Home > Td5 > Oil Recommend |
Try Opie......
http://www.defender2.net/forum/topic1061.html?highlight=td5+oil First post..... ![]() If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 ![]() ![]() ![]() |
Done
...Thanks ![]() |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
Assuming you mean the engine oil,i always put 5w30 fully synthetic in mine i use Quantum oils which is VWs, own brand (castrol in a different container).Never had any problems using this. 2005 Td5 90 XS
Steve |
I do mean engine oil
![]() I have about 3 litres of this spare........ Would it be OK for topup ? http://www.opieoils.co.uk/p-68977-shell-he...e-oil.aspx 2008 TDCi 2.4 XS CSW |
10w40 will be fine in our temperate climate.I think this is what the hand book actually recommends. 2005 Td5 90 XS
Steve |
Which of these is best for TD5, both are on offer ATM
http://www.halfords.com/webapp/wcs/stores/...yId_165581 or http://www.halfords.com/webapp/wcs/stores/...yId_165581 I think i have 5/30 in ATM, it would be for topup JD 2008 TDCi 2.4 XS CSW |
johnszs Member Since: 16 Aug 2010 Location: Hereford Posts: 459 ![]() ![]() ![]() |
Both are listed in the handbook
I have just put 10w-40 in mine ![]() |
I would use the ford spec one as it is spec'd for current models you could always check your last invoice for you service to see what oil was used 2004 TD5 Defender 90 xs station wagon |
ordered
