![]() | Home > Technical > 110 Td4 & Autoradio |
Verdone Member Since: 30 Apr 2008 Location: Gent Posts: 67 ![]() ![]() ![]() |
I hope u havent entered it 3 times else its blocked and i think u will have to go to the dealer ...
Normally its really simple, u just look for the code on ur battery its in a small plastic bag, then u just fire up the radio enter the code and then press 5 or 6 to confirm. U have to see the code though so dont just enter 0410 .. U have to press like number 2 four times to get the four and then number 3 once to see 1 ... I hope u understand ![]() Greetings Verdone |
PhilSHLRC Member Since: 15 Jun 2008 Location: Lyon Posts: 2 ![]() ![]() |
thanks for your answer... when you have "0", you press 10 times or you didn't press the key ? ![]() i will go to my landrover dealer... but this dealer is too incompetent... ![]() |
I didnt press the key
