Home > Puma (Tdci) > Cruise control episode 3 The end! |
Finally yesterday I finished installing the cruise control!
It works very very fine Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Many thanks to Nakatanenga! Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
19th May 2013 9:22pm |
May be I create a SUV!!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
3rd Jun 2013 9:10am |
Nice work as ever Dgardel.
Was using the workshop manual you supplied yesterday, you'll never know how useful it was to me and how grateful I was! Then again you probably do! Thank you. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
3rd Jun 2013 9:16am |
Thank you Mal Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
3rd Jun 2013 9:18am |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 |
Great Job Daniele !
Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
3rd Jun 2013 9:43am |
If you have a TD5, build the cruise control is very easy, you do not need any eletronics. here the circuit (work on NNN and MSB ecu) BLACK CON C0658 Click image to enlarge - P1 & P2 are buttons (OFF - MOM ON) - I is switch - L is LED (no resistors needed) P1 = SET and SPEED INCREASE P2 = PAUSE/RESUME The switch, allows you to manually enter (LED ON) or exclude cruise avoiding accidental use. The cruise will not work below 50 km/h. A security elemenst, in addition to the brake switch, also linked the clutch switch. Pressing the brake pedal or clutch exclude the cruise control . The first button, P1, serves to set the desired speed by pressing it once when it is reached. Once setted you can increase a km/h at a time for each time. The second button, P2, used to suspend momentarily the cruise and to restore it to the previously set speed when it is deemed appropriate. Before proceeding with the Assembly you will need four plugs be inserted into the connector. The plugs are manufactured by Tyco-AMP and are identified with the number-1 183025. Connectors Click image to enlarge bought here http://it.farnell.com/jsp/search/productde...sku=151075 and you can use the Disco 2 CC switches stalk Click image to enlarge Let me know Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
3rd Jun 2013 2:53pm |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 502 |
The terminal pictured, with the Tyco part number 183025-1, is to fit a 1.5mm Superseal connector, it's not correct for the ECU connectors. The Red and Black ECU connectors are from the Tyco Econoseal III 070 series, the correct terminals for the ECU connectors are Gold tipped - Terminal part number - 175104-2 and 344113-1 Wire Seal (Green) part number - 347874-1 The standard Econoseal III 070 Tinned terminals can be used, but are not correct for the application -
That's a D1 cruise control switch. The D2 switch looks similar on the outside of the steering cowling, but uses a different mounting arrangment, with a separate bracket, inside it - . Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' Last edited by PaulMc on 12th Nov 2014 1:20pm. Edited 1 time in total |
3rd Jun 2013 6:07pm |
thank you Paul for the details Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
3rd Jun 2013 6:27pm |
megatoad Member Since: 07 Jan 2012 Location: Hertfordshire Posts: 358 |
Hi dgarel & Paul
Yes I have been looking at this option, but so far the switches have been exorbitant on the old fleabay. I am certainly tempted to have a go and now that you have identified the terminal part numbers thats even better. Any suggestions on wireing guage chaps? Just a caveat to those who glance accross this thread and have not looked into the inbuilt CC in a TD5. It will NOT work properly if you have changed your transfer gear ratios from a Defenders to a Discos OR if you have an overdrive as the ECU will be confused by the incorrect engine rpm compared to roadspeed and dissengage. As my TD5 is standard and I do a lot of cruising at 60 for my commute I really want to fit one, especially the cheaper route.[/i] He who dies with the most toys wins Defender 90 & 110, S1 80", Disco 1, S111 88 LRSOC & CVLRC |
3rd Jun 2013 8:08pm |
http://www.ebay.co.uk/itm/DISCOVERY-ES-STE...0629084001 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
4th Jun 2013 5:17pm |
