Home > Puma (Tdci) > 57 plate 2.4 puma XS Central locking and starting problems |
Sockpuppet Member Since: 17 Sep 2011 Location: Leicester Posts: 479 |
Does the emergency code disable the alarm. If it does then it could be a reciever for the alarm.
2nd Jun 2013 1:02pm |
jameshutch Member Since: 02 Jun 2013 Location: Yorkshire Dales Posts: 2 |
how do you find the emergency code?
2nd Jun 2013 1:05pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20487 |
Handbook most likely. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
2nd Jun 2013 3:39pm |
Toplink Member Since: 05 Dec 2010 Location: Somerset Posts: 159 |
Sounds like a knackerd fob unit.I have a 57 plate and have had to replace 2 fob units so far.
Aparently all the elecronics on LandRovers are customer led inovations Well thats what one of Guy Salmons sales guys told me,at the time I was telling him that electronic hand brakes are crap. Its never over in my land rover. 2007 Defender HTop. 1952 Series One 80" 1977 Muir-Hill 111. 2014 Triumph Tiger800xc 1999 Discovery 2 td5 1982 Ransomes TSR300D. 2002 Yamaha XT600e. 2010 Freelander2 (the wifes) 2008 John Deere X140 |
2nd Jun 2013 4:57pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1790 |
Emergency Key Access code should be in the handbook, otherwise you'll have to get someone with a reader to get if off the ecu.
Keith |
2nd Jun 2013 5:15pm |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 |
have you followed the fob battery changing instructions in the manual to the letter ?
IE Within the vehicle and within 5 minutes : 1) turn the key to position 2 and then remove it 2) Prise off the fob cover from the key ring end 3) remove the battery from the bottom with a small flat end screwdriver 4) press either lock or unlock button to remove any residual current 5) Insert a CR2032 battery + sign to the top/front 6) Push the cover back on the fob and from outside the vehicle press the lock button at least four times until it locks - then unlock. Job done ! I replaced my battery recently simply because its been in for 2 years now and there's quite a few posts about all sorts of shenanegans resulting from worn out fob batteries |
2nd Jun 2013 5:53pm |
