![]() | Home > Puma (Tdci) > Water ingress |
Taking it to a dealer is no guarantee that the problem will be fixed as sometimes they cannot or do not replicate the circumstances under which water gets in. Fixing leaks in Defenders can sometimes mean several trips to the dealers and even then people have had to DIY. Steve.
The issue of dirt collecting under the seal is very well documented and unless the dealers remove the screen (which they are very reluctant to do as there is a risk of breakage) the cause may never be cured. Read the link posted in the quote below from over 18 months ago for more information..... If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
