Home > Puma (Tdci) > Puma Pedal Locks
Page 1 of 3 123>
camelman
Puma Pedal Locks
Anyone got experience of these on a Puma? I know x-eng do them for the TD5 but not for the puma yet....
Post #239930 31st May 2013 11:17am
CSK do a Pedlock. Not sure if that's of interest to you or not? Thumbs Up $W33T $0U7H3RN $UG4R
Post #239932 31st May 2013 11:19am
camelman
thanks for that, was really looking for one that blocked access to all of the pedals.
Will keep looking Rolling Eyes
Post #239936 31st May 2013 11:24am
Ard'case? $W33T $0U7H3RN $UG4R
Post #239949 31st May 2013 11:42am
K9F
Like this? Puma one top quality well made. Thumbs Up ADRENALIN..... Thumbs Up
K9F wrote:
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #239962 31st May 2013 12:16pm
camelman
I've notice a few guys on the forum appear to have these already.
Where do people end up storing them as they appear to be quite chunky and I wouldn't want to get whacked on the head by one if it all went pear shaped!
The X-Eng version appears to be fixed to the floor and just flips up when required?
Post #239963 31st May 2013 12:22pm
K9F
Stash mine between the seats in the rear with a bungee. Initially they seem a pain in the butt, nevertheless once you've got the knack of fitting and storing it becomes 'second nature' and the 'comfortable feeling' you get knowing you've added that extra layer of security is well worth the small effort.
The reason behind a few members having them will be the 'group buy' that was orchestrated, quite a few took up on it, that's when I got mine.
http://www.defender2.net/forum/topic7162.html?highlight=adrenalin If you go through life with your head in the sand....all people will see is an ar5e!!
Post #239967 31st May 2013 12:26pm
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
You are correct with the X-Eng one. It is fixed to the floor, and folds down to the floor when unlocked.
It is a beautifully engineered thing and I love mine. It takes at MOST 3 seconds to lock, and about the same to unlock. And it won't smack you in the head or need tying down anywhere.
the downside is I don't think it fits the puma defenders.
Post #239984 31st May 2013 1:57pm
rossy
I sense a Killer90 post & pic coming on saying 'look at my homemade ones' Laughing
Post #240007 31st May 2013 4:24pm
K9F
Hope not! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #240020 31st May 2013 5:08pm
JSG
The Adrenalin ones are superb bits of kit Thumbs Up Very well made, secure locks, easy to put on and fiddly to take off (which is how it should be) Thumbs Up John
2011 Tdci 110 CSW XS
Post #240022 31st May 2013 5:15pm
Egghead
X-Engineering pedal lock does NOT fit Series or Tdci / TD4 / Puma Defenders or Td5 with AirCon. I have been eagerly waiting for X-Eng to release one for the Puma, however I have just seen this from their site:
X-Engineering wrote:
Question:
When are you going to produce a Pedal Lock for Puma / Tdci vehicles?
Answer:
We produced a number of prototypes for this, however, our focus group rejected all of them because it was necessary to drill holes in the body of the vehicle in order to fit. We felt that the resistance to drilling holes from Puma owners would make the device unsalable.
Instead we are concentrating on devices which can be fitted using only exposed fixings and existing holes - one of which looks quite promising.
Unfortunately, we do not think a pedal lock which works in the same way as for other Defenders is a viable product.
http://www.x-eng.co.uk/New_FAQ.asp?FAQID=45
I think this is a real shame. The beauty of X-eng's product is it sits on a hinge and folds out the way securely when not in use so as camelman pointed out it won't whack you on the swede when things go wrong! Assuming it doesn't breach any patents there must be an opening in the market for someone else to make a Puma version that folds away?? Eh Killer? Wink
Post #240029 31st May 2013 5:41pm
Green Machine
@Mal: in the pics above of the Adrenalin lock, what's the slotted separate strip? Assume it's associated with the row of bolts in the bottom of the main guard? I've got a Shire Fabrications lock (which fits the bill great for me) which seems quite a lot simpler than the Adrenalin version, just intrigued as to the design of it.
I don't carry mine in the vehicle, just use it at home. Going to sort out a proper fixing / lashing for it at some point. I also have an X-Eng gear lever lock, which I use when out and about. Use the two in combination at home. Thumbs Up 2005 Td5 | 90 Station Wagon | Tonga Green
Post #240057 31st May 2013 7:11pm
party monkey
England 2005 Defender 110 Td5 XS CSW Cairns Blue
This should link to the full range they do....
http://shirefabrications.com/services Jon - 110 td5 [sold]. Currently Defenderless.
Post #240067 31st May 2013 7:47pm
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
The problem with security devices like this, as already mentioned, is storage. I was looking forwards to the X-Eng gear stick lock for the Puma, but gather there is a problem and so no such device will be available. I already had a 'DiskLock' which takes up quite a bit of space, and I also have a 'Hardcase' pedal lock for my Series One. I think to have both in a 90 would take up quite a bit of space unfortunately. Euro-Leafing to infinity and beyond.....
Post #240117 31st May 2013 9:22pm
Page 1 of 3 123>
