Home > Maintenance & Modifications > REAR DOOR STRUT
Page 2 of 2 <12
diggers1981
2009 Defender 90 Puma 2.4 XS CSW Santorini Black
I recently bought one of these, they are very good and pretty easy to fit, I bought mine for a vehicle pre 2002 (they do 2 models I think pre 2002 and post 2002) And I paid Just over £60 for it I think.
Post #239677 30th May 2013 11:38am
GUM97
LandRoverAnorak wrote:
chopcat wrote:
just out of interest why would these not fit my 2000 TD5?
is is the door that is different?
Yes, the rear door is a completely new design from around 2002. I'm sure I've seen kits to fit the earlier doors too, though. Paddocks, maybe?
Pre 2002: http://4x4overlander.com/nakatenanga-pre-2002-door-stay.html An engine to TDi for!
Post #239686 30th May 2013 12:07pm
ZeDefender
Yup - I think you have to trim the door card for that one (not for the later ones). Tell someone you love them today because life is short.
Post #239687 30th May 2013 12:08pm
MartinK
I fitted mine from Leeds (Brendan) a couple of weeks ago.
The hardest part was getting the door trim off...lots of pulling but it was all OK.
4 holes to drill into the door braces, and 4 rivets (supplied) (iirc it was 3mm holes). No trim trimming on the Puma.
It was a good time to get Dinitrol into the rear door recesses, and also some Dynamat before refitting the trim.
A pretty quick job with great results.
I wish I had taken pics now Embarassed Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #239871 31st May 2013 7:32am
BarneyRubble
England 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Likewise fitted the Naka...... one from Brendan.
Only now the back door rattles constantly - anyone else get this? Barney
D4 - 2016 Graphite, Montalcino Red
Written Off - 2010 90 Hard Top, Stornoway Grey
Post #239879 31st May 2013 8:12am
MartinK
^^^ good pic, shows where the 4 holes need to be drilled.
Also a good time to get the dinitrol, ACF50 and Dynamat in there Thumbs Up
Interesting laminate-flooring in the back on that picture Exclamation
...no did you take-off the old/original bracket for the original door stay??? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #239908 31st May 2013 10:11am
BarneyRubble
Yes, took the sliding arm off, but left in the sprung "catch" that held the old arm open - didn't think it could come loose, but worth checking.
I insulated the back with a rigid foam/plastic, and boarded it out with some left-over oak veneered mdf. Barney
Post #239911 31st May 2013 10:21am
Mountain_man
Wales
I made my own on my (very early) 110. Mounted it the other way around though as I wanted to utilise the hinge bolts as the main fixing point on the door and also to keep the face of the door flush with the inside in case I build a store drawer system and want to utilise the maximum space.
My original strut from an old tractor door didn't last long but I managed to source a new one from a German company for the best price possible Very Happy
BTW the rear is now carpeted out so it looks a bit tidier! Laughing
Post #239912 31st May 2013 10:22am
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
This is a good point...do these struts preclude the fitting of a drawer system that is virtually flush with the rear door (or at least any more than the standard door keeper/strut)...
cheers
simon
Post #239916 31st May 2013 10:48am
cabell
Travel adjustable?
I'm wondering if these gas struts are adjustable. I have a 255/85/16 (33") spare and am concerned that the strut will push the tire into the tail lamp. Anyone using one of these with big tires?
Post #247921 1st Jul 2013 1:24am
LR90XS2011
On mine the standard wheel hit the rear panel if opened too enthusiastically so I fitted the NAK strut so the door dosnt open to 90 degrees just fitted the bracket sligthly further towards the passender (opening ) side of the door. You should be able to do the same. As other have said before the strut is a bit keen as standard so Im carefull to hold the door when opening. DEFENDER 90 TDCI XS,
Post #247923 1st Jul 2013 5:24am
K9F
Re: Travel adjustable?
Not at all, my spare wheel rim alone is 10" wide and does not foul at all. With the strut the door will only open so far unlike the original set up where the door open point was dependant on the force applied to it. Mine originally did foul with a standard boost and without a strut. Hope that makes sense. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #247927 1st Jul 2013 6:04am
leeds
We run 255/85/16 on swing away wheel carriers.
OK you have to take a few moments to decide on best place to mount the bracket so that the drawer does not scuff the door card or door opens too far and spare wheel hits light etc.
When you remove existing door strut care needs to be taken that spare wheel does not hit the rear panel.
Yes the gas strut can be a bit keen when new. Simple solution is release handle and put hand on the door so you control it opening and do not allow it to open with a bang!
Brendan
Post #247935 1st Jul 2013 7:12am
Page 2 of 2 <12
