Home > Maintenance & Modifications > Replacement brake pipes |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
On my 300 I replaced the pipes using a kit from Automec. All cut to size and all connectors attached. Was much easier thank I thought it would be.
http://www.rimmerbros.co.uk/Item--i-GRID010541 BM52 |
12th Feb 2013 9:36pm |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 |
Order the pipes from your main dealer they will come already shaped for an easy fit. 2005 Td5 90 XS
Steve |
12th Feb 2013 9:48pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5864 |
That's a good thought, I might just give them a buzz. 1999 Defender TD5 110
12th Feb 2013 9:54pm |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 |
Or you can put copper brake lines on....they'll last much longer
Some on ebay, and Rimmer do a full ready-made kit here http://www.rimmerbros.co.uk/Item--i-GRID010541 Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
12th Feb 2013 10:02pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8097 |
i would make my own using a flare kit.
or run braided flex from the calipers to a bulkhead join or even straight to the mc. depends what your using the vehicle for. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
13th Feb 2013 6:54am |
Ordered from Automec today. Full hit, both pipes on rear axle, pipes for the front and the one that runs down the chassis rail (front/back) 1999 Defender TD5 110
29th May 2013 12:30pm |
can I suggest you soak the flex pipe joints from the chassis to the T connection on the rear axle with loads of WD40 or similar. Mine was a right sod to remove and undo , gave up in the end and bought a new flex pipe and T connector. BM52
29th May 2013 3:33pm |
I've got new flexis to go on, braided ones but a good soaking will be in order with Plusgas etc. 1999 Defender TD5 110
29th May 2013 3:39pm |
Just to be clear i was referring to the chassis to T connection and not the one to the calipers.
A grinder became my friend on this job BM52 |
29th May 2013 3:44pm |
I hope I dont have to break out the grinder! 1999 Defender TD5 110
29th May 2013 4:51pm |
