![]() | Home > In Car Electronics > Range Rover Entertainment Centre |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20612 ![]() ![]() |
You wouldn't be able to have the two screens in the Defender if that is what you mean? Due to the layout. The features it has though is possible. If you go double DIN you can have all of that including DAB or if you go single DIN you can have it all except the DAB. I know I don't know why they don't start making the single DIN units with DAB built in.
![]() If you want similar go aftermarket don't try and go for the same kit as it is likely Eqoque specific and you'd probably pay twice as much to cap it off. (And it won't fit) Also with the 2DIN option you'd need a new dash. ![]() β½οΈπ’οΈβοΈπ§°πͺ |
wholejobs Member Since: 16 Feb 2013 Location: Huntingdon Posts: 46 ![]() ![]() |
Cheers.
The RR unit is a single screen albeit a double din effort. Appreciate it wouldn't fit without major mods but would be nice to have something installed that looks like it belongs if you get my drift. Will have to look at DD as like the screen size for the SAt Nav which makes it all a bit clearer. Any suggestions on a suitable unit that anyone has tried and used? Price point not a major issue as prefer to pay upfront for a decent unit that does all I want rather than a cheap unit that might not last! Chris B 2012 USW X Tech |
Has the RR got the Harman Kardon system in it? An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
Yep pretty sure thats the one. Chris B 2012 USW X Tech |
I apologise I just realise your talking about a RR not an Evoque.
![]() ![]() Have a look at these: http://www.justkenwood.co.uk/shop-online.aspx/multimedia Bear in mind prices are for everything in one. Also some of them are used by the Colt Car Company (Mitsubishi) so the TOTR Shogun has these built in among some other models. Chillin In The Backwoodsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
Nick-St Member Since: 23 Apr 2013 Location: Surrey Posts: 267 ![]() ![]() ![]() |
Just been looking for a single DIN with everything - as you say, it doesn't seem to exist! |
Just seem to discontinue them instead.
![]() So what are they trying to say..... They have to have HU's with a 2" faceplate screen as the KIV or forget a screen all together. ![]() ![]() ![]() β½οΈπ’οΈβοΈπ§°πͺ |
I would still go for the KVT526 if it was me though. Everything is capable on there except one thing. DAB.
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2025 ![]() ![]() |
Are you referring to the Range Rover L322, Range Rover Sport or something else?
In the Full Fat Range Rover L322 model (New shape is the L405), the Harmon Kardon Logic 7 system is brilliant. However it is designed to fit into the car and the dash. Most of the control systems are in the boot, and it's operated via the touch screen (in 2006MY) and then was upgraded in the 2010MY cars. This is different to the first model RRS, which uses the D3 green screen (rubbish IMHO) If you are interested I can post the pages from the Rave manual to show the components. I doubt you'd make it fit. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
One of my current options is the KVT526 + Bluetooth + Nav + Camera. Shame about the DAB though... The other choices are DNX7230 in double DIN adapter (but only if the switches can be moved with no cutting!) or a Garmin Dezl 760 with a camera input... All have pros/cons, so can't make up my mind! |
Like mine then although on the bulkhead instead. ![]() β½οΈπ’οΈβοΈπ§°πͺ |
Go for the 526. ![]() ![]() β½οΈπ’οΈβοΈπ§°πͺ |
Its a 2012 RR Sport Autobiography with the Logic 7 system. Its a great system as you say and yes it's dash mounted with seperate CD mounted below. Didn't realistically expect to be able to fit this in the Defender without major mods but something with similar functionality would be great. Like the idea posted elsewhere of the modified dash to suit a double din. Not sure how much difference it would make but just looks more like its meant to be. Im a fan of DAB due to the number of stations you can't get on FM/AM such as 5livesportsXtra etc. Thats more imporatant than Ipod / CD etc. Reversing camera is a useful addition as well. My lad inisist it must have a TV receiver as well but don;t see much use myself! Chris B 2012 USW X Tech |
They did up to the 2010MY cars (09 plate onwards) as they had the HDD version. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
