Home > Td5 > Defender Won't Start.......
MattPoss
Evening,
Was out and about in my 2002 Defender TD5 last night and got home no problem, ran great and never spluttered or anything
Went out to it this morning, turned the ignition and waited for the Glowplug Light, turned the key and it would turn over but wouldn't fire up. I can hear the in tank fuel pump going and it will turn over no problem but it just won't kick into life
I've looked at all the fuses etc. Anyone have any ideas as to what it could be?!
Thanks,
Matt
Post #238989 27th May 2013 4:05pm
excossack
Starter motor packing in ? Mine would would do it mainly when after a run and it was warm. First thing in the morning or after work, it would spin nice and quick but not fire. Ended up with a replacement. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #238991 27th May 2013 4:10pm
MattPoss
Never thought about that. It spins nice and quick but just won't burst into life
I hadn't been driving it hard last night and it showed no signs of being sluggish or anything. One thing was the fuel light was on but only just
I've only had it a couple of weeks but so far it's started no bother at all, in fact it's started first time every time without turning over much either
It seems as though it's not getting any fuel?!
Matt
Post #238992 27th May 2013 4:16pm
bob neville
Beat me to it John Thumbs Up
Starter sends a signal to the injectors, no signal = no fuel to run on.
There could be a number of other reasons, battery on its way out causing immobiliser etc to play up - does the fuel gauge drop to empty when you crank the vehicle ?
Immobiliser could have a fault. ECU could have a problem.
Have you tried to purge the fuel system, could have a leak somewhere and got air into the system.
2013 Defender 90 CSW - sold
Post #238994 27th May 2013 4:20pm
MattPoss
Hmmm, if it was the starter would it not have been a bit temperamental?!
I'd have to double check but I in the fuel gauge drops to empty when it's turning over. What would that indicate?!
Thanks so far Thumbs Up
Matt
Post #238996 27th May 2013 4:27pm
bob neville
Starter will only send a signal on vehicle start up obviously, ECU will take over from there. If there has been an electrical failure in the starter it could be intermittent or just fail, depends what has happened.
Fuel gauge dropping to empty is a sign of a battery on it's way out. I have been ignoring this sign for a couple of months and not fitted the new battery I have sat here, almost a disaster because of this yesterday when winching Embarassed I should add, the gauge will behave normally after the vehicle has been run for a while as there is extra charge in the battery.
Post #238998 27th May 2013 4:35pm
excossack
Also I thought the speed of the starter was checked by the Crank Position sensor - i.e too slow aint starting, no fuel. 1999 Defender TD5 110
Regards
John M0VAZ
Post #238999 27th May 2013 4:39pm
bob neville
Correct Thumbs Up I guess the signal is a combination of the starter spinning fast enough for the crank sensor to say everything is OK to deliver fuel ?
I suppose the crank sensor and its cables would also be worth checking.
Post #239000 27th May 2013 4:44pm
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
Matt
ECU is losing power when you crank, the fuel gauge is powered by the ECU try all your relay connections. It may also be immobiliser related.
Sorry to add more things to think about.
Edit: or is it the temp gauge powered by the ecu?
Post #239014 27th May 2013 5:28pm
ashfordsv
Ireland 2006 Defender 90 Td5 SW Java Black
I had a similar problem when starting mine, it turned out to be a loose relay beside the ECU. It maybe a long shot but make sure the connectors and wires around the ECU are not loose.
Post #239222 28th May 2013 12:31pm
barbel jim
Also worth playing with the relays under the drivers seat. Thats what mine used to do. Cured by cable tieing it in tight, no problems for over 4 years Whistle
Post #239225 28th May 2013 12:41pm
ashfordsv
oops, I meant to say relay Embarassed , thanks Jim
Post #239227 28th May 2013 12:56pm
MattPoss
Thanks to everyone so far, great to get a response so quick after joining Thumbs Up
I spoke to my local specialist today who suggested starting with the Relays under the drivers seat so he's got a couple for me tomorrow, said its pretty common and a cheap place to start
Will see how I get on
Post #239328 28th May 2013 5:11pm
barbel jim
mine didn't even need a relay.First time, I tightened up the clips with a pair of nips. That worked for a couple of months, but then it came back. I then wrapped a cable tie around the offending relay and board and tightened up. Hey presto sorted about 4 years ago. Wiggle the relays first, whilst trying to start, if they click in and out (rattle) sorted. It could also quite easily be a dud relay. Or something else Big Cry Let us know how you get on Thumbs Up
Post #239379 28th May 2013 8:31pm
landy andy
Have you tried locking and then unlocking. My has had similar when it got confused and did not turn imobiliser off when unlocking it.
Andy
Post #239393 28th May 2013 9:18pm
