Home > Puma (Tdci) > Defender Puma 110 DC Tailgate Chequer Plate |
I don't know of anybody that makes one specifically, but isn't it essentially just a rectangle that would be easy to cut to size?
Regardless, I'm pretty sure it's not Puma specific. The design probably hasn't changed significantly since around 1958. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
12th Oct 2011 8:09am |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 |
The basic plate tends to be the same - what changes is the cut outs for hinges, wiper motors, cables etc on the doors - however for a drop down tailgate I don't see an issue.
Even for a door I would expect a late TD5 to be the same as a Puma (could be wrong though) John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
12th Oct 2011 8:47am |
Just thought I'd resurrect this thread.
I'm having similar issues and wondered if anyone had solved the problem with a commercially available solution? I was thinking about an armourfend type solution as I think the issue with a piece of flat aluminium plate is that the surface is not truely flat but has a raised series of loops to aid sliding boxes and such in and out of the back. |
15th Jan 2013 3:28pm |
Tribord Member Since: 20 Apr 2013 Location: France Posts: 220 |
I have this on mine:
Click image to enlarge It is not just a flat rectangle, but is also bent over the top surface. I stand on this with the tailgate closed when accessing the roof rack. It was already on the vehicle when I bought it, but it has a plate from N&J : http://www.njaluminiumlinings.co.uk/ |
26th May 2013 7:49pm |
Thanks - seen the covers from N&J; however if they aren't routed on the back side then they can't truely fit flush to the surface. However, that might be a little OCD and once bolted down gaps may not be apparent.
certainly a foam type gasket would help this. In the end, I have fitted some 50mm wide helicopter tape to the top edge. |
27th May 2013 12:16pm |
