Home > Puma (Tdci) > dealer ineptitude |
munsterlandy Member Since: 17 Dec 2009 Location: munster Posts: 52 |
grockle
might need 2 bips to make sure i've enough time to heat the milk to perfect temp for me and to let the murphys settle for you! if you are passing sometime fancy a spot of courier work? |
7th Feb 2010 5:43pm |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
ok mate that sounds good ,what do you need couriering 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
8th Feb 2010 8:12am |
will be looking to get few bits of kit like genuine floor mats (over €140 here from stealer!), A bar/winch bumper,lightforces, clear lamps, HID kit, side steps that sort of thing.
don't expect anyone to bring all that though !! haven't started to look at best deals yet and delivery may be easier from supplier. what you reckon? used to deal with famous four (excellent) and mm when i had a classic rangie but not delt for few years to be honest. recommend anyone for toys? anyone else recommend any suppliers in particular? |
8th Feb 2010 1:39pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
Devon4x4 are good and fast dispatch NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
8th Feb 2010 1:42pm |
thanks fekete. in past have found that some don't want to ship across the water so will try devon. unless grockle will pick up a sankey for me too for everything to fit into! |
8th Feb 2010 1:51pm |
two in tandem ok 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
8th Feb 2010 2:26pm |
you could stick mine on top upside down to keep everything nice and dry
8th Feb 2010 6:06pm |
here goes. just got truck back from dealer. had clutch replaced due to usual springs issue. they also replaced hub flanges (all 4), uj bolts, diff-lock selector rod mechanism, fuel rail, fuel rail sensor, heater recirculate control mechanism. supposed to replace cable for control but obviously didn't cos 1st time i tried it driving out the gate it detached again due to stiffness! cable either not replaced and seized or pinched somewhere between heater box & control lever? anyway she drives much better no judder & shifts silky smooth, clutch light which is a first for any LR I've driven since childhood!! 1st at 10 was s11A main bone of contention is that the b4stard who did clutch took stanley knife to tunnel carpet to access gaiter for gear levers! I just cannot believe that someone would do that even if they didn't like the vehicle. It's sliced from heater vent right out to the seatbox end of the hi/lo selector. anyone any ideas about how to keep my cool when i bring it back again? ps i know that it was mentioned on another thread sometime ago but has anyone got the lo box indicator light working on the dash? if so was it a remedy or working from new. rant over for now many thanks |
3rd Mar 2010 11:26pm |
ring LR customer services to make them aware of what the butchers of Ireland did,when ours went in for it's first service some arse danced on the wing tops
anyway how are ya Ml 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. Last edited by Grockle on 7th Mar 2010 7:50am. Edited 1 time in total |
4th Mar 2010 8:45am |
Cannonball Member Since: 19 Jun 2009 Location: Co Laois Posts: 150 |
With you there Munsterlandy, carpet also "Stanley Knifed" in similar fashion when transfer box and clutch replaced late last year! Difflock inoperative since then as well, just called in to get it looked at, now have to leave it in to have the gearbox dropped again for a few days when I get back from holiday at the end of March.
4th Mar 2010 11:49am |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4731 |
Sounds like criminal damage to me. I would log a complaint with the local Gardai then tell the dealer principal what I have done. I'd also e-mail LR uk with the same info. I presume they will replace the trim they have damaged.Try contacting SIMI and the Dept of consumer affairs. I would not let it rest. Good luck. 1982 88" 2.25 diesel
4th Mar 2010 5:29pm |
hi all. still seething especially seeing as no call back today from service dept re carpet and heater. dealer only 20 k away so will take a run in tomorrow. spudfan fancy trip down seeing as you seem to be the right person to deal with the shower of langers! must say i'm a little quiet for these guys so will have to get myself worked up for them i reckon. cannonball did they say anything about carpet regarding replacement? I don't think that I could accept anything less than new replacement. grockle will be making call to LR after conversation tomorrow. also got new steering box (new not service exchange @ €975 + 21%vat ) total spend on this visit on parts is just under €3000 gear lever still rattling due to selector wear as per previous posts. originally told that box had to be out to check. Having driven it I asked if they replaced it & I was told that he forgot to check it! well seeing as carpet is shredded he can look at it from inside vehicle now without too much difficulty any of our UK brethren had similar issues with trim destruction when gearbox out? |
4th Mar 2010 9:18pm |
there's a mod for the rattling gearlever/selector 2.4 90 XS
5th Mar 2010 8:21am |
Munsterlandy, not making an issue about carpet replacement yet as still having problems with gearbox/clutch/transfer box that I hope will be resolved the next time it goes in to the dealer for a "holiday". Presume they would only slice it again if replaced now!
Hoping, now that OHM group have taken over the Land Rover franchise after LR Ireland closed down last year, it will be easier to get these outstanding issues resolved locally, as for the last 12 months or so my dealer seems to have been facing an uphill battle with LRUK to get warranty issues sorted promptly. Another problem is that many dealers down here have not had much in the way of TDCi stock to test drive to compare with my vehicle. At the moment it seems the attitude is the usual "well it is a truck after all and characteristic of the marque". However I have had the chance to drive a couple of 2009 models in the UK which are far superior to the driveability of mine. Second annual service is due in June and if the problems are not sorted I'll be off to Toppings for a second opinion/warranty work. I have been in contact with them and they would be only too happy to rectify any warranty issues. |
5th Mar 2010 9:31am |
