Home > Technical > PIAA Driving Lamp Kit
KarlB
Australia 2010 Defender 90 Puma 2.4 XS CSW Rimini Red
Land Rover only offer the PIAA Driving Lamp Kit (LR006851) as an option for Puma Defenders. Does any one know anything about these kits? What are the lamps equivalent to in the branded PIAA range?
Post #23805 8th Feb 2010 4:17am
Grockle
we had them fitted to ours give a good spread of light 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #23810 8th Feb 2010 8:03am
K9F
Welcome Karl!
KarlB welcome to the site. I believe (but sure I shall be corrected if not) that the driving lamp option available to the Puma Defender is the one where the lights are mounted adjacent (slightly inboard) of where the main headlamps are, they are mounted on the bumper itself.
They also have a wattage rating over here of 65 watts to comply with legal legislation. This was the only 'standard' option that was available four months ago when I discussed it with the parts department at my local dealers.
In my opinion (and it is just that a personal opinion) you're much better off considering the myriad of alternative lights available on the market Roo, Lightforce etc. etc. to get the look and requirements you need. You'll also get them a damn sight cheaper where you are compared to what we pay in 'Blighty.'
You also have to consider future modifications, winch bumper, a-bar, chequerplate etc. and if they will still fit. Happy hunting. Hope this helps.
There are a couple of threads about it on the site.
http://www.defender2.net/forum/topic2340.h...spotlights
http://www.defender2.net/forum/topic2277.html?highlight=lamps If you go through life with your head in the sand....all people will see is an ar5e!!
Post #23813 8th Feb 2010 8:39am
KarlB
I should have said in my original post I am in the process of making some final decisions on what options to put on a new D90 I plan to order in the next few weeks. The 90s are just returning to the Au market after several years absence.
Grockle: what made you decide on the PIAA kit as opposed to aftermarket lights?
Does any body know if the loom is available separatly from the lamps? Part number?
Post #23898 9th Feb 2010 12:24am
lrdxb110
United Arab Emirates 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
I have the land rover safari 5000 lamps and land rover had the hella lamps on the accessories brochure for the puma which I fitted under the bumper couldn't fix them over because of the radiator which would be covered and since I have a A frame bar. '08 LR Defender 110
'08 Mini Cooper S - Sidewalk
'86 MB 500 SL
'79 MB 450SEL 6.9
Post #24697 19th Feb 2010 8:47pm
Cibit
We have them on teh TD5 and they are awesome, but we lost a cover from one when we had the canoe on the top. Replacement costs £34+VAT Big Cry 59 2.4 110 XS Utility
55 TD5 110 CSW Special Vehicle
Post #25139 25th Feb 2010 7:31pm
RED-DOT
I have Hella Dynaview mounted on the bumper where the LR units should go.. they have 2 100w bulbs in each unit and one stays on with main beam and one comes on when cornering to that side to see the apex of the corner... very handy in a Landie... not!! 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #25177 26th Feb 2010 9:00am
