![]() | Home > Puma (Tdci) > How did LR make the 2.2 bonnet more soundproofed than 2.4? |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
Its not the bonnet but a plastic cover on the engine that distinguishes the 2.2 from the 2.4 in terms of accoustic embellishments. From what owners have said, however, the 2.2 is quieter anyway - plastic cover or not.
Think Dgardel was looking at fitting a 2.2 cover on his 2.4. Believe quite a bit of butchery is involved. If you go through life with your head in the sand....all people will see is an ar5e!!
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 ![]() ![]() ![]() |
Maybe the DPF acts as a sound deadener...
and the various holes in the bulkhead where pipes and wires go through to the inside are sealed better in the 2.2
