![]() | Home > Puma (Tdci) > Strangest thing |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 762 ![]() ![]() ![]() |
...happened to me today!
I turned on the key, waited that all the usual lights lights went out, turned the engine on...and after two/three seconds the engine turned off and immediatly turned on by itself! ![]() Anybody has any explanation for this? Could this be an early symptom for troubles to come? Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
Check the battery connections and the relays under the seat Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Check the following relays which are related to the starting circuit....
R100 and R102 Also at the Battery Junction Box..... Link 5 rated at 60 amps Fuse 5 rated at 30 amps Just a couple of pointers for you. In the absence of a multimeter or electrical savvy just check for security of attachment. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Are those relays under the passenger (for me as I'm LHD) seat?
And what or where is " Battery Junction Box"? Thank you both... Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
PM sent.
![]() Edit***** Glad you got the e-mail and pleased to be of assistance. Hope you get it sorted. ![]() Treat every day as if it is your last....one day you will be right!! |
