- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
leeds
![](templates/vbnew/images/spacer.gif)
OK going back to a previous life used to test polymers and this did include some ropes but not winch lines.
The larger the ratio of rope diameter to the drum diameter the higher the apparent strength!
For winches the larger the drum diameter and the larger the pulley block diameter the better
However you do run into certain physical restraints. For instance a 1 m diameter winch drum and 1m diameter pulley block will give an increase in strength over shall we say a 10 cm drum and pulley block. However the increase in strength would be vastly outweighed by the disadvantages of a 1m winch drum on a 4x4
Like many things a practical sensible compromises has to be taken!
Brendan
15th May 2013 9:24pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
