Home > My Defender > New roof lights
Egghead
New roof lights
Changed my old Hellas for some LED lights and can now illuminate several counties worth for much less power! The old weak lights were starting to fill with water. New ones are IP67 rated so hopefully will fare better whilst it continues to bucket down. Rolling Eyes
Old:
New:
Post #235757 15th May 2013 3:02pm
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
got myself 4 of those yesterday from Tim.... Putting Dreams on Drives at JLR Solihull..
Post #235787 15th May 2013 4:16pm
iPints
United States 1994 Defender 90 300 Tdi CSW Epsom Green
Like those lights, can I ask where you got them and how much they cost....
Post #235809 15th May 2013 4:49pm
adafish
have a word with Tim @ www.mobilecentre.co.uk ..... Putting Dreams on Drives at JLR Solihull..
Post #235820 15th May 2013 5:02pm
Egghead
Special offer from The Man For Land Rovers. Couldn't resist when I saw six of them hooked up on an old county. Practically turn anybody standing nearby translucent when they are on!
The new lights are JW Speaker 700s
Saw similar on Ebay available from the USA, however the price from The Thatched Garage was much more competitive.
The old drill holes for the Hellas were too low on the roof rack to fit the lamps upright, so to save drilling new holes I hung them upside down. I actually prefer them hanging under the bar in a low profile way, but the wind noise is more than the former lights. - Not that it is noticeable above the rest of the Deafeners roar.
Post #235828 15th May 2013 5:27pm
adafish
like i said....try the main dealer Tim... Whistle Putting Dreams on Drives at JLR Solihull..
Post #235836 15th May 2013 6:05pm
how did you route the power cables ?
Post #235837 15th May 2013 6:07pm
adafish
...........cancel that last ME-MO, he had the lot..... Mr. Green Putting Dreams on Drives at JLR Solihull..
Post #235840 15th May 2013 6:14pm
K9F
Remember not to look at them as they can blind you. Mind you they are great lights but will still make your eyes water a little when you see the price.
Cool Shocked Shocked If you go through life with your head in the sand....all people will see is an ar5e!!
Post #235841 15th May 2013 6:23pm
Phoenix90
United Kingdom 2007 Defender 110 Puma 2.4 USW Stornoway Grey
Which beam pattern did you go for? They look good Thumbs Up
Post #235887 15th May 2013 8:12pm
Egghead
As there were already lights on the roof I used the existing cabling - although it received a lot of tidying up seeing as the old wiring was utterly pump! (Bits everywhere, all different colours and types, loose disconnected wires etc!! There was even a spare feed up there but it was non-live??) Currently the wires come up out of a hole in the roof, which is a nice water ingress point Rolling Eyes I was advised by the seller that the wiring should go up via the snorkel I have but as there was already that hole in the roof it was a bit late to rectify properly.
You can see the feed to the roof rack in the side angle shots...
Thanks. I think the beam pattern is the Spot Pattern (as opposed to Flood or Trap patterns?) - more info can be got from the Forward Lighting Catalogue which you can download from JW Speaker (The Model 700 is on page 35)
Like K9F said, the nightime display is not something you want to gaze at for very long. (They are bright enough in the daytime!) The quoted output of each lamp is 780 Lumens, so I would believe people can probably blind themselves with systems putting out over a thousand lumens or more! Here is a shot with the whole lot on... sidelights (which are subject to MOT failure due to not being white), HID headlamps and the new LED roof bar lamps. Them rabbits will see me comin' now! The camera lens seemed to pick up reflections and all sorts such as the yellow dots visible near the reflections off the bonnet.
Post #235954 15th May 2013 11:55pm
