Home > In Car Electronics > Anderson connector/10AWG Cable
excossack
I have picked up on my travels an Anderson connector that has stamped on the plug/socket WC 50amp 600v.
The wire currently attached has written on it 10AWG 105deg c 600v.
My questions are;
What rating is the cable at 12v?
Looking around on Ebay I have seen 10awg cable for sale as used on Amps etc. Would this cable be suitable to use with these connectors so I can create an extension lead for running into a tent and also for using as a feed into a trailer for work lights. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #235543 14th May 2013 8:35pm
mikeh501
10awg is 50 amps @12v. same as the anderson connector you have.
you can feed whatever you want from it up to 50 amps. Any LED type lights will be fine with this as they draw very low current.
Whatever you do, make sure you fit a fuse inline to protect from a dead short.
these guys are excellent for automotive wiring products.
http://www.altecautomotive.co.uk/cable-36-c.asp
Post #235550 14th May 2013 8:50pm
excossack
A couple of fuses will be going in, one near the battery and one at the other end either in the tent or on the trailer.
the cable I spotted was this
http://www.ebay.co.uk/itm/10AWG-AWG-red-po...20d26f4de2
Shall have a look at the link you gave - cheers. 1999 Defender TD5 110
Regards
John M0VAZ
Post #235553 14th May 2013 8:59pm
K9F
The photo depicts 10 AWG cable but the write up below states 8 AWG in your link. Question Make sure you get the right cable for the current draw.
Ironically I scoured all the usual suspects (RS, Farnells etc.) on the internet today for a decent quality heavy duty fuseholder and fuse for a project I have on the go on my Land Rover with a view of placing it close to the battery. I did not wish to run off the Mega Fuse fitted as standard on the positive terminal or fit a blade type fuse.
Here are the links for the one I sourced it may save you searching and suit your needs...... Thumbs Up
http://www.halfords.com/webapp/wcs/stores/...yId_265889
http://www.halfords.com/webapp/wcs/stores/...yId_265878 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #235566 14th May 2013 9:28pm
excossack
Cheers K9F. Big ass fuses! 1999 Defender TD5 110
Regards
John M0VAZ
Post #235571 14th May 2013 9:35pm
K9F
Have edited post above. Look at cable sizes in the advertisement. 6mm cross sectional cable is best, sod AWG! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #235573 14th May 2013 9:37pm
excossack
Cheers, I had not spotted that. 50amp would be over kill for charging a phone/LED lights in the tent unless I decide on an inverter or running a cool box. 1999 Defender TD5 110
Regards
John M0VAZ
Post #235576 14th May 2013 9:38pm
K9F
Best to use the correct 10AWG/6mm cable protected by a heavy duty fuse and then individually protect the circuits with correct rated fuses in the tent. Why limit/reduce the capability of the main supply? It always allows you the flexibility to expand increase the loading without the need to rewire your Anderson. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #235579 14th May 2013 9:42pm
excossack
Sounds like a plan to me. These Anderson connectors I have come from the battery packs we use in the UPS's at work Smile...I have a drawer with a few of them in.... 1999 Defender TD5 110
Regards
John M0VAZ
Post #235581 14th May 2013 9:44pm
K9F
Rolling with laughter Rolling with laughter I have a very similar drawer and a few more besides. We too use a lot of UPS's for backup on the vessels for communications, radar etc.
Post #235584 14th May 2013 9:47pm
excossack
We get new battery packs and they come with new Anderson connectors. When replacing the batteries, its a shame to send the Anderson connectors off to get binned. IYKWIM, Very Happy Very Happy 1999 Defender TD5 110
Regards
John M0VAZ
Post #235589 14th May 2013 9:54pm
excossack
Gone for some lengths of 10AWG with 40amp fuse / holder. So will be adding some Anderson connectors front and rear for powering lights etc when camping and also so I can charge a battery on the Harvey Frost crane in readiness for some work lights to go on there as well. 1999 Defender TD5 110
Regards
John M0VAZ
Post #236800 19th May 2013 10:35am
K9F
Ironically I am currently heading down a similar path. With the add-ons I have there are a number of fuses in different locations. So I have decided to tidy everything up and have a central auxiliary electrical distribution centre adjacent to the battery with room for further additions if required. Never been one for the standard automotive relays so sourced some Releco 12 volt 10 amp DPDT relays that have LED indication and a manual switch for testing the circuit or changing them to latched relays if required (bit more versatile than the automotive ones). Have added a spare relay for next addition. Wago terminals will be fitted adjacent to the relays for terminations together with a 32 amp terminal block again for future terminations. As the fuse box is rated at a maximum 50 amps I have protected it with a 60 amp 'megafuse' (see link above) which will be connected directly with the 10mm cable depicted to the battery terminals. All have been enclosed in IP55 boxes with watertight skintop cable glands. I shall complete the build and just fit the whole kit and kaboodle in one go. Also have an auxiliary Wago filled box for under the driver's seat to pick up the current lighting circuits to move them to the passenger/battery side. All work in progress......
Post #236802 19th May 2013 11:08am
excossack
Nice. Are you the ships spark ?
The phrase, "He's going for it" springs to mind. I shan't show you my current under drivers seat layout...Its chaos and in rush job stylee I used red and black cable for most of it......so sorting out the wiring is a puzzle at the mo and needs re-doing completely! 1999 Defender TD5 110
Regards
John M0VAZ
Post #236806 19th May 2013 11:46am
K9F
Yes, one of a team of three for two conventional vessels and three high-speed catamarans. My wiring was a mess (albeit a safe mess) too. I suppose it's akin to builders houses always looking like a building site. It was time to do something about it or add further to the spaghetti that was there. It will make future additions/adjustments and any fault diagnosis a breeze. I will leave sufficient cable excess so the whole box can be lifted out of the battery compartment and worked on. Will not need coloured cable as the relays have convenient diagrams on the side but will label the Wago terminals, what goes where etc.
Foward planning ain't it great? If I'd had the foresight at the beginning I wouldn't have needed to revisit everything.
Laughing Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #236807 19th May 2013 11:52am
