Home > Maintenance & Modifications > LED driving lamps with an SVX grill or with a light bar?
Page 1 of 3 123>
RFAA
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
I bought a new 110SX from the dealer and paid for both the soft A bar (£500) and the SVX grill and lights with the dealer promising to refund the cost of the grill/lights (about £750) if he couldn't get it to fit with the A bar. As it happened, he got the order wrong and fitted the lights/grill but left off the A bar as it wouldn't fit (apparently the SVX grill sticks out further than the normal grill and blocks access to the bolts on the bumper for the A bar).
Anyway, I am starting to love the new SVX lights but also want to put some LED spots/driving lamps on, but without the A bar to mount them on, I am stuck...or am I?
The first option seems to be to put a lighting bar above the screen but then I am limited as to height as my office car park has about 1.5 inches clearance over the roof of the car. I have read about LED light bars such as the Rigid Industries one and that sounds great, but I would prefer something more like the JW Speaker oval lights or the Lightforce 140's/170's. Does anyone know if any of these can be mounted at the front of the roof whilst ensuring that (i) they don't light up the entire cab and (ii) they do not exceed the height of the back part of the roof?
Alternatively, has anyone else managed to mount an A bar on to the bumper in conjunction with an OEM SVX grill and lights (thereby allowing me to put something lower down and not worry about car park roofs????
Post #235455 14th May 2013 4:22pm
Fits an Xtech thou
Post #235457 14th May 2013 4:25pm
K9F
The brackets for the A-Bar are not complex. Any decent fabricator would be able to manufacture a set of extended brackets to bring the A-Bar out further. With all the different fixings available and the fact the grill can be fitted after the A-Bar lower brackets have been secured (by leaving the top brackets off) and the A-Bar in place it wouldn't be too difficult. What he will need are a set of originals to work from.
I had to do the same to 'make' my bumperette fit after fitting a swing away wheel carrier and had to have completely different brackets made and welded into place.
Straight brackets...
Angled brackets to facilitate fit...
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #235458 14th May 2013 4:29pm
And here
Post #235459 14th May 2013 4:31pm
RFAA
Beautiful car, Ken!
I suspect the answer is that the stealer couldn't be bothered and was rushed for workshop time Rolling Eyes , however, if I can get the A bar on then that opens up a whole load of oprioins and means i can put something decent on the front without worrying about height.
Were there any fixing problems (possibly spacers or some adaptations) with your grill and does the A bar sit right up against the grill or is there enough space behind>
Post #235461 14th May 2013 4:32pm
RFAA
Thanks K9F....maybe I am giving the stealer a bit of a hard time....probably could go to an indie or a specialist and see what they can achieve!
Lovely car, BTW!
Post #235463 14th May 2013 4:34pm
MartinK
The Flatdog light bar could be mounted further forwards to give more clearance...here's mine (but with normal LR PIAA spots):
 Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #235464 14th May 2013 4:36pm
K9F
I think you may be right as if you look at the link below of an SVX grill the mounting points for the lower A-Bar brackets are clearly visible and with the grill off readily accessible.
https://s3-eu-west-2.amazonaws.com/i.hubnu...2248c9.jpg
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  If you go through life with your head in the sand....all people will see is an ar5e!!
Post #235469 14th May 2013 4:45pm
TBC its an easy fit Thumbs Up
Post #235471 14th May 2013 5:00pm
Defender SVX
United Kingdom 2008 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
Yup easy fit Thumbs Up
LR standard spots need the modified brackets to fit and without padding, touch and rub the grill Big Cry and are a pants light compared with my JW Seaker headlamps.
Light force 170 look like they'll fit well or copy kens smart led light bar :thumbsup:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Formerly mao99999
16 Focus RS Nitrous Blue.
11 FFRR TDV8 Vouge SE Black Black.
08 DEFENDER SVX SOFT TOP (SUPERB)
08 DEFENDER 110 DCPU Stornoway grey (Overland Exploration Unit)
05 Fiesta ST 150 Van
04 Jaguar XKR 4.2 Supercharged V8
02 DEFENDER 90 TD5 (next years soft top project)
95 DEFENDER 110 CSW 300 TDi Phoenix black
95 DEFENDER 90 HT Monti Carlo blue COUNTY 300 TDi
67 109" SERIES 2a TUNED 200 TDI
64 DAVID BROWN 990 rat look
55 86" SERIES 1
Post #235498 14th May 2013 6:03pm
a13x
Mao - which JW lights did you go for? Black or chrome and do you have better pics showing the front of car?
I am in the process of deciding which I prefer and you have the same set up as me.
Thanks
Post #235511 14th May 2013 6:39pm
couple of other options ...
1. fit rigid industry dually d2's inside the bumper
2. replace the 90mm spots with H9 HIDs
or man up and buy a rigid industry e-series 40" LED bar, 16k Lumens, bullet proof and blinding
Post #235520 14th May 2013 6:54pm
Defender SVX
Thanks
I went for the black as that's all that was availible with the side lamp at the time. If I was to choose again I would probably go for the chrome as it would match better with the other lamps.
I'd like to fit led aux lamps also. I've no more photos to hand but I'll take a couple of shots of the front come the weekend as it's stored away for the winter. Thumbs Up Formerly mao99999
55 86" SERIES 1
Post #235523 14th May 2013 6:57pm
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
I bet the dealer got the wrong A bar poss not A/C one which I guess is slightly shallower or shorter brackets ? It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #235535 14th May 2013 7:23pm
leeds
RFAA, since you are based in North Yorkshire how about coming to the Spring Adventure at Harrogate this coming weekend?
There you will be able to see a lot of different light combinations. Speaker LED headlights v Lightforce v Lazer lights on our stand. Decent lights can be a reasonable investment so take your time and get as much information and compare lights as possible.
Brendan
Post #235564 14th May 2013 8:27pm
Page 1 of 3 123>
