Home > Tdi > smokey 300tdi
joetetley
United Kingdom 1995 Defender 110 300 Tdi SW Epsom Green
smokey 300tdi
hope you can help when cold in morning or end of the day she starts with usual black smoke then when i set off smoke goes bluey grey for about half a mile then no smoke any ideas
thanks
Post #217486 9th Mar 2013 6:42pm
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
Blue smoke indicates oil:
I would first check your turbo oil seal. It's probably leaking and dumping what leaks through down the exhaust.
Post #218062 11th Mar 2013 5:24pm
Arierep
Portugal 1995 Defender 90 300 Tdi SW Alpine White
The startup black smoke is normal for the 300tdi.
The open loop injection system lets excess oil in the sistem, which is burned when starting.
As for the rest, look into the turbo seal
Post #235383 14th May 2013 1:25pm
