Home > Camping, Caravanning and Holidays > Towing Mirrors
Mynstral
United Kingdom 2015 Defender 110 Puma 2.2 USW Montalcino Red
Towing Mirrors
H All. I need to get a set of towing mirrors. Looked on another thread and will get the aeros from milenco. BUT do I go for curved or flat? Any thoughts?
Myn. Smoke me a kipper I'll be back for breakfast.
Post #232271 2nd May 2013 5:57pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
I tried a set of aero and grand aero from Milenco but could not get them to fit the Land Rover miror heads
Got a set of extended arms and larger heads.
Post #232275 2nd May 2013 6:10pm
I've succesfully used the Milenco mirrors like this:
The cable tie was for my own peice of mind on first use but was later abandoned as they worked perfectly.
These were fitted to the longer arms that Milenco supply. Darren
Post #232287 2nd May 2013 7:09pm
ARC99
Big Cry Never thought of doing that, more money wasted.
Post #232291 2nd May 2013 7:13pm
Sorry Sad Darren
Post #232299 2nd May 2013 7:45pm
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
I did mine like that after looking at threads last year. Should have got the square mirrors rather than the oval ones as they look a bit odd ( that's if square are available)
Dj 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #232318 2nd May 2013 8:41pm
ickle
I have a set of Grand Aeros that may be available, used once, one careful owner...
keith
Post #232323 2nd May 2013 8:50pm
WarPig
I use Millenco Grand Aeros (square heads) with convex glass, fixed to my mirror arms. I bought the Millenco extended arms that extend the mirrors out further so that I can see the actual sides of my caravan.
Post #232325 2nd May 2013 8:53pm
Laurie
I use 'Wolf' mirror arms.
In for normal, out for towing.
Post #232354 2nd May 2013 11:36pm
WarPig
Check that you can see the actual sides of your caravan though, if you want to comply with law/regs etc. Most mirrors including Millencos dont comply when fitted to a Defender straight out of the box.
Saying that though, most police officers probably aren't aware of the law when it comes to towing mirrors unless its a knowledgable traffic cop. Even then they probably arent too interested and would probably just offer advice if they pulled you over. But you only have to be unlucky once, or be involved an a traffic accident that ends up getting investigated. Or stopped by VOSA!
Post #232430 3rd May 2013 12:18pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
As above. Just make sure you secure them to the arms, not the mirror or you'll crack the glass as you tighten it.
Extended arms are a good idea, I only just see the back end of the van.
Other thing to look out for if you have a raised air intake is that you'll need to attach the off-side arm to the rear face of the mirror arm (the bit nearest you) otherwise every time you open the door, the end of the mirror will hit the RAI and fold the mirror in. Gets very annoying after a while. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #234338 10th May 2013 10:17am
WarPig
So true. Ask me how I know Big Cry
Post #234875 12th May 2013 1:05pm
megatoad
United Kingdom 2006 Defender 110 Td5 XS CSW Zambezi Silver
After reading this thread I decided to get the Milenco mirrors. In general I found they are good, however I dont trust how they attach to the mirror are, especially as one of teh clamps has already started to tear.
I recently decided to install heated mirrors to the 110, but at the same time decided to add Defender mirrors to my 80" too.
So I purchased a new set of mirrors and arms, plus a heating kit.
While modifying the new arms to take the cables it occurred to me that it would be a good idea to drill the arms to take the boltsfor the Milenco bar clamps.
As you can see that this works quite well.
Plus it should also stop the annoying folding of my mirror arm when I open the door and it clips the RAI, took me a while to realise why the mirror was always folding in Laughing
 He who dies with the most toys wins Smile
Defender 90 & 110, S1 80", Disco 1, S111 88
LRSOC & CVLRC
Post #281190 11th Nov 2013 9:59am
That's pretty neat. I'm surprised that you've had a problem with the Milenco clamps though, as mine have been faultless.
I solved the problem of them hitting my RAI by mounting the drivers side mirror on the front of the arm instead of the back. Darren
Post #281204 11th Nov 2013 11:40am
megatoad
I think I was a little paranoid, so possibly overtightened the one to the outside, that barely sits in the arm, Also wrapped cable ties round for added security.
Rolling Eyes He who dies with the most toys wins Smile
LRSOC & CVLRC
Post #281208 11th Nov 2013 11:55am
