![]() | Home > Puma (Tdci) > TDCI fault codes and MAF/EGR dilema |
The P1103 code is what I call a 'nuisance' one and I get it periodically. After a few driving cycles that one would clear anyway along with the MIL light that accompanies it if no reoccurence arose. The remainder do seem MAF/EGR valve related and I personally think you're going down the right track.
To be sure I would drop either Lorryman or Pete at BAS a message as they are 'in the know' and would be only too willing to advise further. ![]() Treat every day as if it is your last....one day you will be right!! |
william8 Member Since: 03 Apr 2013 Location: Motherwell Posts: 259 ![]() ![]() ![]() |
Thanks for the quick reply, is it worrying that I have no MIL light on the dash?
Ill have a wee fiddle and give pete a call after I've swapped out the maf . William |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20620 ![]() ![]() |
EGR 'chatter' whilst on idle is what my EGR was doing before it stopped working correctly. It was also the time it started causing problems and also affecting MAF readings too. I replace the EGR for a new one and had no trouble at all since. If you want the EGR shut by a map then IIRC then general thinking is that the EGR has to be in perfect working order first or it will still cause problems even if blanked off and not in use. (Happy to be corrected on this though) TheThunder Rollsπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
The egr plates are good but the only true cure is a egr close in a remap ? Using a plate with a hole eventually the engine management light will now old is your vehicle it may need a software update also personally and this is what I did with my 2.4 I had the egr shut remap file from Pete and also blanked it right off with no holes
I have done the same on my 3.2 ![]() If you need any more info let me no Kind regards steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
can i have your engine steve ?
![]() Yeah i think it will be a case of going to Pete. However as a short term solution (im a student) can i remove the EGR valve and clean it ? William |
Good luck is all I will say. ![]() β½οΈπ’οΈβοΈπ§°πͺ |
Hmm lol depends how much money you have for my engine lol
I supply Petes stuff so could do it although you need a complete new remap I'm afraid but if I was to do it I can update the software at the same time at no extra cost ![]() Steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
pope10001 Member Since: 15 Oct 2011 Location: Dulverton Posts: 489 ![]() ![]() ![]() |
It is a pain in the arse, but not too bad. In total it took about 2 hours to remove disassemble clean and put back on. Well worth having a clean out though, my EGR now closes properly. Regards, Mark |
Mark - Mine was tuck closed IIRC rather than open. What did you use to clean with? I assume it was coked up? TheThunder Rollsπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
Mine had a slight crack keeping it slightly open with the build up of carbon.
I used carb cleaner and the wife's toothbrush, she wasn't impressed... It came up really clean though. Regards, Mark |
Sounds good mark so did yours go through the shut down open and close cycle? But you had fault codes for it?
Just trying to see if we have the same symptoms. Sounds like a good wee job for after the exams ![]() |
Steve, I've been running with a remap and EGR blank with a hole since May 2010 when Robofarmer first knocked them out with no issues whatsoever. http://www.defender2.net/forum/topic3115.h...egr+blanks ![]() Treat every day as if it is your last....one day you will be right!! |
K9f have you go egr shut in your map though ?
As if you run with just a hole in a plate it will throw the light up as I tested it on the plates starting with the smallest Steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
