Home > Puma (Tdci) > battery tray
Marius
South Africa 2011 Defender 110 Puma 2.4 SW Keswick Green
battery tray
So in the end I bought a Varta stop start AGM plus 105 ahr as a replacement. It's 4cm longer but the same width so I just need to grind off the lip on the one side of the existing abttery tray.
How do I get the stay/plate off. Seems it's bolted from the bottom. Anything special I need to know about removing it. I see there is a plastic protection thing on the bottom. How does that come off?
Post #233059 6th May 2013 6:20am
parktag
France 2008 Defender 130 Puma 2.4 HCPU Zermatt Silver
Just the four bolts under the vehicle. 130 crew cab
98 V8 Disco
Post #233574 7th May 2013 7:10pm
ZeDefender
Perhaps take the opportunity to waxoyl etc. under the tray and under the vehicle at the same time - typical rust spots Thumbs Up Tell someone you love them today because life is short.
Post #233644 7th May 2013 9:01pm
Marius
damm.....only saw the post now on the waxoyl.
I took out the plate - bent the sides down (remember the new bat is now 4cm longer but the same width and height. Worked great!!!
I can recomend this battery: Varta Start-stop plus AGM 105 amph. It packs 15 amph more, fits great and 150 CCA more! Lets see how long it lasts.
Post #233694 8th May 2013 5:07am
