Home > Puma (Tdci) > Alarm aerial mod
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Alarm aerial mod
Was at a loose end so I thought I would mod the length of the alarm aerial. Had a look through some old posts and was looking for an orange wire with a white/grey trace which was kinds short looking. Anyway I couldnt find it, but the wire in its place on the far left as you look at the module is now black and goes way up into the top of the dash, is this the new and improved aerial?
Post #230502 25th Apr 2013 6:27pm
borderterrier
Anyone?
Post #232732 4th May 2013 8:14pm
K9F
What range have you got with yours as it is? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #232734 4th May 2013 8:26pm
borderterrier
Varies, from the passenger side it's 20m or so, but the drivers side I am touching the side window!
Post #232735 4th May 2013 8:38pm
K9F
I think that you have some form of modification as 20 metres was totally unachievable from any angle without the modification. 4-5 metres maximum. I extended mine up the driver's side window pillar and get about 20 metres from that side but a reduced distance from behind the passenger's side unless I stick the fob against my bonce. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #232751 4th May 2013 9:39pm
What would happen if it was some how linked to the radio aerial? Not sure if that is possible or indeed a good idea though. Whistle
(probably isn't a good idea) TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #232754 4th May 2013 9:43pm
