Home > Maintenance & Modifications > Fixed
ClaireWright
United Kingdom 2008 Defender 90 Puma 2.4 HT Keswick Green
Fixed
Diff lock selector fixed at last on my landy Smile
Post #231994 1st May 2013 11:55am
Baggie Austin
England 2009 Defender 90 Puma 2.4 HT Alpine White
My Censored diff lock wont engage, gear stick wont budge over.
Post #232063 1st May 2013 5:16pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
the light doesnt come on in mine Big Cry and not sure if its engaging either
steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #232064 1st May 2013 5:26pm
PK1
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
There is a light Shocked Defender 110 TDCi XS SW
Range Rover Sport HSE
Post #232092 1st May 2013 7:52pm
DRW58
Scotland 2001 Defender 90 Td5 SW Epsom Green
Ihad he ame problem no light couldn't get the diff lock lever to go far enough over.
It was the linkage seized, it looked to be moving fine but when it all came out the lower link had rusted solid.
Took it all bits loosened it off and threw it back to gether some slight adjustments and hey presto diff lock working again.
The light issue could be a faulty switch, check with a wire between the terminals to make sure dash bulb is ok then work out if switch needs replacing or linkage is stuck. The switch can also be in too far preventing the diff lock engaging.
BEWARE if you replace the switch don't do as I did and over tighten it as mine sheared off leaving the threaded brass barrel still in the transfer box housing, had to get a set of easy out on it.
All in all it's a pain in the arse removing the gear box tunnel but satisfying to sort it out yourself.
There is a video on youtube somewhere I got the link from this site so if you hunt about it's there and worth a watch.
DRW I built a garage for my Mini
With a place for everything and everthing in its place.
Ten years down the line there's a Mini in there somewhere, and Censored all's where it should be!!!! Ho hum
Post #232101 1st May 2013 8:14pm
PK1
Just been out and had a quick check - no dash light Big Cry - will check bulb tomorrow - didn't even realise there was a light Embarassed Defender 110 TDCi XS SW
Post #232103 1st May 2013 8:20pm
ClaireWright
Glad mine is sorted..next job ball joint on axle..back to garage Friday...
Post #232136 1st May 2013 9:17pm
