Home > Maintenance & Modifications > Fixing Air Intake Grill so it can't fall off again
Following on from my experience - and now others who have had the same thing happen:
http://www.defender2.net/forum/topic17458-15.html
I decided not just to get a new one from the dealer and refit, even with the vehicle being very much under warranty.
Looking in the parts book it appear the thing is held on with (3) insert & (6) bush:
but on taking mine apart I only found one of the items present and from the photo it is hard to say which as they both appear to be identical. However, I only found 3 of the pins from the back grill - so 2 have made a bid for freedom - possibly down the air intake tubing:
I decided to drill out where the tabs had been and insert bolts through c clips sitting on the wing edge of the air intake hole:
I had to cut down the front edge of the c clips as it was showing around the edge of the grill when refitted:
I put a little bit of copperslip on the internal threads of each c clip but not too much that it would end up coating the air filter
So next job is to see if i can find those missing 2 pins :lol:
Post #231742 30th Apr 2013 1:07pm
Nice mod Thumbs Up
Post #231750 30th Apr 2013 1:25pm
farmer giles
watch out supacat, someone will be asking why your rivets aren't painted
Post #231756 30th Apr 2013 1:34pm
I did similar with mine only using an aftermarket air intake grille. Thumbs Up TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #231757 30th Apr 2013 1:43pm
f15hie
England 2013 Defender 90 Puma 2.2 XS CSW Havana
Came out 1 sunday morning to find it hanging on by 1 plastic spike, thought cant be bothered to take it to dealers although only 2 months old. So, out with the drill, drilled grille where the broken spikes were, pulled the broken spike out with pliars left the plastic retainers in and with 5 self tappers secured back. Used mrs black nail varnish painted screw covers and in 15 minutes back nice and secure Thumbs Up
Anyway why arent the rivets painted :bow:
Post #231769 30th Apr 2013 2:46pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Same thing happened to my old Defender, not a great design by LR.
I used a few blobs of silicone sealant to stop it coming off, never moved after that.
Post #231851 30th Apr 2013 7:34pm
Mattyboy
United Kingdom 2007 Defender 90 Puma 2.4 HT Santorini Black
great idea, don't use supper glue like i did, it still fell off and just took the paint off the wing with it! 07 Defender 90 TDCI
98 Defender 90 300 Tdi
Land Rover Freelander
MG B GT
CBR 600
AEC Matador
but no washing machine
Post #231935 1st May 2013 7:42am
f15hie wrote:
Anyway why arent the rivets painted Bow down
Is that an "in" joke - which rivets are being referred to?
Post #231940 1st May 2013 7:56am
farmer giles
shame on you!
(the rivets next to the rear wheel arch on a 110 are fixed after factory painting so don't get a lick of paint)
Post #231960 1st May 2013 8:59am
OK - thanks for the explanation - slow morning here Smile
When considering whether I would use black screws or stainless bolts I did think the stainless bolts were nicely set off against the unpainted rivets...just didn't want to mention that on here Embarassed
Post #231961 1st May 2013 9:03am
Farmer58za
South Africa 2012 Defender 90 Puma 2.2 SW Tamar Blue
Ha ha!
Today, a little "persuasion" on my TDCi air intake grill caused it to pop off. Yes, it was stuck on with the dreaded super glue!
It's Saturday so I just cleaned off the cover at the lugs and fixed it in place with Silicone and duct tape. Tomorrow, I will remove the tape and it will be just fine.
Regards
David
 Dave's not here man...
Post #612125 25th Mar 2017 9:12pm
Farmer58za
Re: Fixing Air Intake Grill so it can't fall off again
Supacat, that's a quality fix. You could also just drill the cover to match the air receiver plastic screw inserts and fig the receiver and the grid with the same (longer) self tapping screws.
Regards
David
So next job is to see if i can find those missing 2 pins Laughing
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Dave's not here man...
Post #612128 25th Mar 2017 9:17pm
