Home > For Sale & Wanted > EP 90 Fuchs Oil for sale in 25 litre containers
familymad
Been meaning to grab some oil for my fleet!
Have bought a pallet of Fuchs OEP220 (EP90 to you and me). Not cheap ebay rubbish but proper military spec oil.
Collection only or postage at your cost
£ 45 for one or £85 for two
If it doesn't sell, have oil until year 2095 for myself Rolling with laughter
15 available Thumbs Up
Fuchs OEP spec lubricants are designed for use in linear or off-set hypoid, bevel and spiral gear units in transmissions, axles and final drives working under severe high speed/low speed/high torque conditions.
Extreme pressure additives enable these grades to maintain effective lubrication in severe automotive conditions of high tooth load and sliding pressure. Selected viscosity characteristics permit these multi-purpose lubricants to perform effectively over wide operating temperatures.
For synchronised manual gearboxes, this range should be used only if lubricants of API GL-5 performance level are explicitly recommended by the vehicle manufacturer.
They are available in viscosity grades SAE 80W-90
Benefits
 Superior viscosity/temperature offering cold flow properties and enhanced thermal stability.
 Excellent resistance to foaming and corrosion.
 Extreme pressure performance to minimise scuffing, welding or galling tooth-wear in severe
load applications.
 Multi-purpose luricants which meet the requirements of many automotive manufacturers.
 Ideal rationalisation grades for mixed fleets.
 Compatible with conventional automotive seal materials used with mineral oils. 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #231591 29th Apr 2013 10:01pm
familymad
Meant to say, it's a mixed pallet and there will also be some 20 litre containers of Shell EP90 which is another mineral based military gear oil. This one has a joint service designation of OEP 215 and used all the way from Landys to helicopter gearboxes!
£40 for one or £75 for two.
AEROSHELL FLUID S.8350
AeroShell Fluid S.8350 is an SAE 90 high presuure gearbox oil.
APPLICATIONS
AeroShell Fluid S.8350 is used for helicopter rotor gears, drive-shafts and pitch control mechanisms and wherever high loads and slow speeds in gears require the use of a 90 EP gear oil. AeroShell Fluid S.8350 is approved for use in various Westland helicopter gearboxes. 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #231606 30th Apr 2013 6:14am
