Home > Puma (Tdci) > P068A fault code
Eduardo
P068A fault code
I have reading a P068A fault code (ECM Power Relay Load Circuit: De-Energized Performance Too Early)
Nothing affected in the driveability but better check to do not have a major problem in the future.
According some WEB page (http://wiki.ross-tech.com/wiki/index.php/P068A/001674)
The causes can be:
Fuse(s) faulty
Ignition Switch faulty
Wiring and/or Connector(s) from/to Power Supply Relay (J271/J317) faulty
And the solutions:
Check Fuse(s)
Check Wiring and/or Connector(s) from/to Power Supply Relay (J271/J317)
Check/Replace Power Supply Relay (J271/J317)
Anyone with experience in this issue?
Cheers and thanks Eduardo
Post #231225 28th Apr 2013 7:14pm
K9F
Hi Eduardo,
Just did a quick search. Lorryman will be the man I would 'pm' first. Thumbs Up
http://www.defender2.net/forum/topic14410.html?highlight=p068 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #231229 28th Apr 2013 7:19pm
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
I love this Forum !
there is no end to the skills and experts on here who galdly share their leranings for the good of others.
Lorrymans post was Fab!
many thanks guys!!
Thumbs Up Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #231278 28th Apr 2013 9:02pm
Eduardo
I did a search in all the WEB but I forgot to make the search here Embarassed Embarassed Embarassed
Quote:
P068-A appears quite often if the OBDII socket is used to power a diagnostic tool or scangauge/ultragauge etc.
Problem solved.
Thanks KF9 for the reminder! Eduardo
Post #231324 28th Apr 2013 11:40pm
Naks
Yeah, that fault code is also stored in mine often since I use a BAS remap tool --
Post #231392 29th Apr 2013 12:51pm
