Home > Technical > Fixed a fuel leak at the rear end |
sidler Member Since: 18 Apr 2013 Location: Netherlands Posts: 12 |
Hi,
This weekend I fixed a fuel leakage and I thought: let's make pictures so it may help people in the future. I discovered diesel on my MY07 Puma 110 leaking from the rear cross member. After washing the car, I saw it was actually coming from the diesel tank of course because rear cross members don't hold Diesel It turned out to be the breather hose that was broken. Actually, it was only leaking with a full tank - that's why. After driving for a year with only a half tank full, I decided it would be better if I could leave on holiday with a full tank. So let's replace the hose. This was easier said than done, because the hose is connected to the filler cap with an easy screw-on hose clamp, and a machine-fitted hose clamp at the other side. After trying to saw or cut the thing, I managed to get it open with a firm hit with a hammer on a tent pole on a screwdriver. Here are the pictures Maybe it would have been better to dismantle the tank, because it's really a *** job to replace it from under the wheelarch, but this saved me a lot of time. Be sure to buy a new hose that is fuel resistant, at some industrial workshop where they maintain generators or boats. They have these hoses. Now up to the next job: replacing my clutch because it's rattling. |
23rd Apr 2013 7:56am |
I did it without removing the tank, but it felt like painting your hallway through the letterbox
The clip that fits the hose to the tank is a nasty one, I managed to undo it with a firm hit on a screwdriver that I held against the little 'hump' in the clip so it came open. Fitting the new hose was also a lot of fiddling, but I warmed up the new hose a bit, tried to stretch it up a bit and put grease on the tube on the tank and that went quite ok. After all I spent about 2 hours with my head under the wheelarch and my arm disappeared between body and chassis, but I think it saved me a lot of time compared to removing the tow bar, stabilizer, tank protection, tank and mounting it all back again. |
29th Apr 2013 10:08am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8009 |
you could also just cut the plastic pipe breather just before tank side of the hole/leak/tear and then use a 8mm (IIRC) female to female push fit connector and add another length of pipe on the other side to extend it up to where ever you need it.
http://www.ebay.co.uk/itm/Pneumatic-Push-I...3ccb794a8f Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
29th Apr 2013 10:22am |
