Home > Maintenance & Modifications > Cor4 air intake
macduff
Cor4 air intake
Just fitted a Cor4 air intake cover in place of my LR RAI. Decided to try this out after seeing the BAS dyno results the RAIs have on performance , and noticing a distinct lack of go up hill .
Not had a chance to try it out on my butt dyno but heres some pics .
Fitting was very easy once I worked out how to drive the rivnut tool.
I've plugged the windscreen frame bolt holes with the RAI bolts/nut covers until I find a less visible solution, thankfully all my bolts weren't corroded in when I came to remove the RAI, though a another winter may have swung that the other way.
Ps supplied very promptly by LRS offroad
 2023 110 P400e
Post #230670 26th Apr 2013 11:51am
macduff
A quick spin on the backside rolling road says its not any slower up hills but hard to say its faster. What was noticeable was its a lot smoother drive under 2k revs and quieter? I used to notice the egr chattering a lot on part throttle urban driving, and its seems to be either less egr activity or less noise directed in to cab . 2023 110 P400e
Post #230834 26th Apr 2013 10:27pm
Thud
United Kingdom 2008 Defender 90 Puma 2.4 SW Zermatt Silver
An air intake cover can make any measurable difference on a defender. I don't believe that for a second.
Rolling with laughter
Post #230850 27th Apr 2013 6:30am
I agree Thud but I think you'll find it replaced a raised air intake in which case I'm sure there would be a noticeable difference
Love or hate the Cor4 design you have to admire these guys for their innovation and originality Thumbs Up
Post #230852 27th Apr 2013 6:46am
bell-auto-services
If a Mantek/JLR snorkle is removed to fit the wing vent it WILL make a difference for sure to power and its delivery. I have tested it on the dyno on several cars with shocking results. I dont know if a COR4 one is any better than the factory plastic wing vent but I for sure know removing the snorkle is.
Pete
Post #230870 27th Apr 2013 7:57am
Thud
I understand that removing the restrictive snorkel will show flow gains. I'm saying that a flash AI cover is no better than a boggo one.
Post #230871 27th Apr 2013 8:00am
bell-auto-services
Prob very true on that note, they all prob do the same as the next just look different.
Post #230872 27th Apr 2013 8:01am
Cakey
United Kingdom 2012 Defender 90 Puma 2.2 XS CSW Santorini Black
Since Pete remapped mine with a rai , it has lots of go uphill 47bhp more go Thumbs Up
And if Pete was kinder to his customers mine would have a huge inter cooler by now Big Cry
I like mine it makes me feel rugged Rolling with laughter and its the only thing I will notice when it falls off
Post #230878 27th Apr 2013 8:22am
macduff
I don't doubt that, though I didn't have a stock placcy one, I didn't like the prices of the KBX? ones and following reports of the stock one being held on by a whim I wanted something slightly more permanent Smile
And as kindly pointed out by Pete of BAS it was replacing a RAI, that doesn't do anything useful in the climate/conditions its being used in that I can see (as it doesn't seal the intake from water ingress and I'm not likely to drive a dust cloud anytime soon) - so probably more a fashion accessory than the Cor4 plate that replaced it. Smile 2023 110 P400e
Post #230879 27th Apr 2013 8:23am
As an added bonus, you'll never be short of somewhere to grate some cheese Mr. Green
Sorry, couldn't resist Laughing Darren
Post #230901 27th Apr 2013 10:35am
Laughing
or open a bottle of beer
Post #230946 27th Apr 2013 2:14pm
rleslie
Scotland 2007 Defender 110 Puma 2.4 XS CSW Epsom Green
Hey Mr Macduff, you never know when coming round from Tarlair you will need a raised air intake, and the dust clouds off the parks at Myrus!
Surly as long as it looks good and gives some performance gain (even in your own head) its worth it........
Post #235721 15th May 2013 1:05pm
mick
What I was wondering is if you remove the intake pipe from where it goes into the air box would that be ok and you can keep your air intake on for bling Thumbs Up
Post #235845 15th May 2013 5:30pm
K9F
Maybe I've read it wrong but why and what benefits would be had? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #235851 15th May 2013 5:49pm
GUM97
I'm assuming he's referring to the graph above with regards to the lower power. If you remove the intake pipe from air box, then in theory you could keep the snorkel for looks (if you like the look of them!), but not have the reduced power that they cause. I personally don't think it would work, as the air intake is on the outside of the vehicle for a reason. An engine to TDi for!
Post #235856 15th May 2013 5:56pm
