Home > Puma (Tdci) > exact process for changing the fuel filter ? |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4646 |
Are the retaining lugs seated properly? 1982 88" 2.25 diesel
25th Apr 2013 9:04pm |
mermoto Member Since: 21 Sep 2011 Location: Essex Posts: 326 |
Here is one I did earlier
starts at 7.22 http://youtu.be/sNFfdnfycYg |
25th Apr 2013 10:46pm |
07PUMADRIVER Member Since: 08 Apr 2013 Location: north wales Posts: 4 |
Earlier in the topic reference was made to drawing fuel through via a bleed tool, where does the bleed tool connect to?
28th Apr 2013 10:18am |
If you do it carefully, as in the video, pre filling the filter you should not need to bleed any fluid |
28th Apr 2013 11:42am |
sat13 Member Since: 06 Jun 2010 Location: Cheshire Posts: 70 |
When I removed my fuel filter cover for the first time I was surprised how heavy it was. I suppose it has to be solid to offer protecion for the filter. So as the plastic butterfly nut seemed a bit weak for that mass of metal I added an extra fastner by drilling a 5mm hole through the cover and backplate. And bolted up with a nut, bolt and locking washer. I know this is now not quick release but my overkill aircraft inspectors brain would not let me be until I had done it. No rattling now. (added to Supacats pic to show approx where the hole is drilled).
28th Apr 2013 12:23pm |
sat13 - I think that might be the best solution - not sure why a quick release fastener has been used here anyway - hardly a daily/weekly service item is it.
28th Apr 2013 6:59pm |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 |
you don't need one. Just fill it with diesel. You don't even have to fill it to the top And by the way Mermoto's video is very good - well worth watching |
28th Apr 2013 8:11pm |
