Home > Maintenance & Modifications > ***LANDROVER****Software Patch has broken my Landie |
chalky Member Since: 09 May 2008 Location: Yorkshire Posts: 483 |
alantd,
hi, it never ever juddered before, it did loose power on pick up several times about the same time they kept replacing the fuel pressure reg last year but i told them it was the EGR ! after 3 visits the EGR was replaced and the lack of power on pick up never returned ! Early on in the year as i said the transfer box seal was deemed to be leaking so it was replaced, the mastic sealant didnt seal and the oil came out back to the dealers on a truck ! Got it back and never really bothered looking underneath for some time and when i did Oil seemed to be dripping off the hand brake housing and the hand brake wasn't as it should be. This was about March / April last year ? The new software version sank my previous excellent fuel consumtion and the whole love story went down hill rapidly from there on in ! resulting in NO windscreen wipers from about the middle of Dec all xmas and new year where it sat on my drive unable to use. By this time i had decided to get shut of it as it had really P!SSED me off, especially when i got the recall telling me my Hand brake was leaking, DEFENDER XS CSW 08 TONGA GREEN |
26th Jan 2010 1:13am |
Sticky Member Since: 07 Dec 2008 Location: Derbyshire Posts: 245 |
I had mine back into the dealer who said there is a new technical bulletin on this with a list steps for the technicians to go through, interestingly he said they needed to order some new wiring as part of the remedial work.
My symptoms are a flat spot in each gear at around 2500 rpm. They originally suggested a new egr but now suggest the fault may be elsewhere. |
28th Jan 2010 10:04pm |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2232 |
On thr 20Th Jan LTB00254 was out part of it reads.
Pete |
28th Jan 2010 10:25pm |
mrwoo Member Since: 03 Jan 2008 Location: Cheshire Posts: 286 |
Pete, thanks for the information I am going to give this to Land Rover on Monday. Do you have a copy of the bulletin? Cheers |
30th Jan 2010 9:34am |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
Woe is me
Mine has turned all erratic. The problem that the patch was supposed to resolve - power loss - started happening much more frequently (although it has been colder - which is one of the supposed triggers) and the MIL came on. The MIL then went out a couple of days later. Then tonight it has started revving in spikes. I accelerate and as I lift off it continues to gun it before dropping, revving, dropping, revving... It's going in to the dealer in a few weeks (I'm abroad quite a bit and can't get it there) so they'll have to find out what's wrong. Is the general consensus that this is purely a software problem, a sticking fuel control valve or the EGR valve? One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
10th Feb 2010 9:18pm |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 |
alantd,
A forum friend of Panama had a "similar" problem time ago and finally was the EGR. At the beginning the dealer thought in the software patch, but its not solve the issue. Failure was different from yours. As he describes, was a noise in the motor that appears when was cold (well Panama are not really cold). If your EGR is in worst condition maybe a power loss can occur I hope can help Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
10th Feb 2010 9:35pm |
Thanks Eduardo.
My dealer is 'on trial'. They appear not to have any technical initiative or skill but can hold a spanner and just have Land Rover Technical Support on speed dial. I can do that so really the only difference between them and me at this point is their 4-post lift. I'm not going to accept "we couldn't repeat the problem". They won't be getting their loan vehicle back until mine is resolved. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
10th Feb 2010 9:43pm |
Sorry I should of rounded this post off since I started it -
The software patch which I thought had broken my Land Rover resulting in a very juddery tranmission during lift off was eventually fixed by Land Replacing the ECU. They spent around a week trying to resolve the issue explaining that they could not revert back to the original software, then one day they tried another ECU off a new defender in stock, hey presto all sorted and I'm back in love again. |
12th Feb 2010 1:22pm |
Mrwoo,
Just a doubt: New ECU installed had also the patch or was with the old software? If the new ECU have the patch, probably during the ECU software upgrade an error ocurred (EPROM memories are quite sensitive to errors) that gives you the malfunctioning. Another thing to think about it Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
12th Feb 2010 2:40pm |
merebrowpaul Member Since: 19 Dec 2009 Location: United Kingdom Posts: 162 |
after i had this software up-date the fuel consumption has gone mad in the teens has any one else found this problem
12th Feb 2010 3:50pm |
Yes i also found fuel consumption to go downhill massively !
My 08 Plate was Spot On before the dealer started chasing an error that wasnt there ! DEFENDER XS CSW 08 TONGA GREEN |
12th Feb 2010 5:34pm |
what is the best way to get accurate mpg figures from my landy so i can take it back to the stealers i work in Brum but live in Preston and i could go down and back home twice on a full tank now i have to fill up in Brum on the second trip to get back home
12th Feb 2010 5:42pm |
As far as I know Eduardo the new ECU has new software, not a patched version though a master copy. The software is definately not the same as the original as I've noticed certain changes which are not necessarily a problem. |
13th Feb 2010 6:51am |
Thanks Mrwoo Eduardo
14th Feb 2010 2:38am |
