![]() | Home > Maintenance & Modifications > ruberising the back |
whiskywalker Member Since: 12 Apr 2013 Location: helensburgh Posts: 11 ![]() ![]() ![]() |
Fantastic job, funny i've just decided to remove my back seats out of my 2004 SW 90 because they just take up so much room and i never use them. Got 2 spaniels so this would be fantastic. I see they have a place in Aberdeen and I'm up there working in a couple of weeks so i think i will pop in and see them. Life time garrentee can't complain at that. O by the way is that a landrover fit ladder anyone help on that?
Thanks for the post |
Ah crikey I have just had the head gasket scare ![]() ![]() Sounds very much like you are buying the 110 a lot of "welcome back ol'girl" pressies ![]() Cardiff is kind of a 2nd home as my partner is currently doing a Phd there. Heading down to pick her up on Friday, then back up to Shrewsbury on Saturday for the Lau concert, then we are off to France and Spain for a month... ![]() Oh and the trick is to keep buying gifts for your 110 so you remain in favour and it'll break down less... ![]() |
Line-X. Where do I start? (I nearly became a Line-X dealer recently!, but I didn't!)
The Line-X coating is simply a Polyurea coating. It really is a great product. It's waterproof, is very abrasion resistant, prevents rust/corrosion, and takes very little time to be applied. The coating process goes like this. There are two main parts to the coating, which are mixed in the spray gun. As this happens, a chemical reaction happens which means that the costing dries within seconds of being applied (5-8 seconds to be precise). With regards to cost, it really isn't cheap! But you get what you pay for! I've currently got Line-X in a number of breakdown/recovery vehicles, and also HGVs, and I've never had any problems with it at all. HTH ![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
MrFlips Member Since: 27 May 2009 Location: Cardiff Posts: 682 ![]() ![]() ![]() |
If you're going down the Line X route, then why stop at just the pick-up bed! Admittedly he's gone a little OTT, but I like the paint on this! Peter
2008 SWB Truck Cab 1952 80" Soft top |
Delskinz Member Since: 18 May 2012 Location: North Devon Posts: 84 ![]() ![]() ![]() |
So wrong but so cool..... |
