Home > Puma (Tdci) > battery
Page 4 of 4 <1234
Rakthi
2011 Defender 110 Puma 2.4 HCPU Stornoway Grey
Looks like RS South Africa has them ... 4,700 Rand or about £340 Shocked
http://za.rs-online.com/web/c/batteries/re...4294959776
Post #227756 16th Apr 2013 9:57am
Marius
South Africa 2011 Defender 110 Puma 2.4 SW Keswick Green
Optima bluetop 75 ah goes for R3900. A bit cheaper...ill just have to mount it sideways.
Post #228046 17th Apr 2013 8:01am
Landlord
United Kingdom 2007 Defender 90 Td5 HT Cairns Blue
K9F and Leeds are both right.
I had twin 1500 Odyssey, fitted well and did the job but only lasted 4 years. Replaced them with a yellow top and a red top Optima which were virtually the same size as the Odyssey.
Wish I had stayed with Odyssey, although I was disappointed with life span they were much better than the Optima's.
Optima's are now 9 months old and are not holding their charge as well as the Odyssey and they have less CCA's.
When its time to replace them again Ill return to Odyssey. 2007 TD5 90 Hard Top
Post #228129 17th Apr 2013 12:40pm
BigWheels
These are all expensive batteries. Don't seem to last that well. My OE battery is now 5 years old & still OK so far, touchwood).
WRT battery size, has anyone fitted batteries in a different place to where they were designed to be e.g. in a boxed part of load space. Less restriction on size & set up, just a bit more wiring needed.
I see Odyssey sell brass terminals for their batteries. Are they better than lead? Also would marine batteries with steel posts be less corrodable? Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #228319 17th Apr 2013 8:47pm
Marius
So.....if the expensive batteries dont last well one might as well just buy a conventional one......
Post #228494 18th Apr 2013 10:44am
BigWheels
Yup. A leisure battert with big storage, CCA etc like Numax for 1/3 the price. Worth a try the first time.
I'd go big O if I found a sale or discount priced one somewhere. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #228730 18th Apr 2013 9:31pm
JWL
I replaced an old leisure battery with one from this lot:
http://www.ebay.co.uk/sch/batterymegauk/m....1439.l2654
Next day delivery and I specified a 110Ah deep cycle/cranking battery that was lower in body size to the original starter battery and it fits alongside in the battery box, it's a bit snug but it works for me and for £74 was a little easier on the wallet.
Post #228738 18th Apr 2013 10:05pm
Marius
Any comments on this battery? What exactly is an AGM?
VARTA Professional Dual Purpose Agm LA 95
or
LA 105
Post #229804 23rd Apr 2013 7:39am
Rakthi
AGM: absorbing glass mat. Instead of the plates sitting in a liquid acid bath, they are "wrapped" with a glasmat that contains the gelled liquid. So they can't spill and don't need filling up.
not 100% correct explanation but close. Laughing
Post #229848 23rd Apr 2013 10:18am
Marius
OK....the deed is done.....
Fitted a Varta start-stop plus 105 amphr AGM in the end.
Same width and height and only 4cm longer. Had to bend the battery tray a bit to accomodate the extra 4 cm, otherwise a flawless fit. 150 more CCA and 15 more Amp hrs.
Post #233695 8th May 2013 5:11am
Page 4 of 4 <1234
