Home > Td5 > TD5 Throttle voltages
Luismi
Spain 2004 Defender 110 Td5 SW Alpine White
I just connect the Nanocom and in a first look playing with it i read the voltage on one of the throttle potentiometers at idle
The values:
1.-0.6 Volts
2.-4,89 Volts
3.-4,92 Volts
Thats wrong i suppose.
any advice?
cheers
Post #229619 22nd Apr 2013 1:50pm
Hola Luismi!
Los voltages.... es correcto!
One of them goes from 0 to 5 (ish) volts as you put your foot down
The other goes from 5 to 0v as you put your foot down, as does the 3rd one
the ECU reads all 3 and works out where the throttle position is.
edit: Here's the pages from the workshop manual to explain it better than I just did <---- .pdf download.
Post #229636 22nd Apr 2013 3:10pm
Luismi
Thank you Diesel_jim
Good to know that this is ok
I though that i may have a problem somewere as from idle 750 rpm i press the throttle and when i release it revs go down as have to be, however don't go strait to 750 rpm it remains i little bit up arround 900 rpm for 2 seconds and then go to 750rpm
this may be the fuel map or it is emdemic of the TD5
Post #229651 22nd Apr 2013 4:12pm
Postmanpat
Ireland 2004 Defender 110 Td5 DCPU Bonatti Grey
mine does the same ... Postmanpat
Post #231754 30th Apr 2013 1:31pm
Luismi
Thats good then.
I tried to find something grong with the car, but nothing, still going strong.
Thank you
Post #231837 30th Apr 2013 7:02pm
