Home > Maintenance & Modifications > Vnt Turbo |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6088 |
I have an IRB one on my 110.
Yes, it makes the engine pull from lower RPM's much better. just like a modern diesel (which all seem to have VNTs or VGTs) Top end power is no different, as the boost is still set at the same limits, but as said, it's just a smooth level of torque all the way. definately worth it I think. Edited 'coz I can't spell "worth" Last edited by diesel_jim on 20th Apr 2013 7:31pm. Edited 1 time in total |
20th Apr 2013 6:37pm |
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1381 |
which part of SUNNY DEVON ? Putting Dreams on Drives at JLR Solihull..
20th Apr 2013 7:23pm |
fixit Member Since: 15 Mar 2012 Location: Sunny devon Posts: 66 |
The bit with no sun
Im not far from hatherleigh if you know were that is Thanks for the replys if if helps to flatten out the torque curve and give the truck a little more at low revs then im thinking it will be on the cards pretty soon |
21st Apr 2013 9:06am |
Jim did you have it remapped as well or did you just swap out the turbo
21st Apr 2013 9:19am |
Alive Tuning Member Since: 01 Mar 2010 Location: Louth Posts: 609 |
Can you drop us an email, with the spec of the Defender you've bought, and details of it's previous owner. It might be that the tuning was restricted, and there is more locked away.
Regards, Gary. |
21st Apr 2013 12:35pm |
remapped with IRB 190bhp tune |
21st Apr 2013 2:14pm |
